When i turn my steering wheel back and fourth it sounds like there is a popping noise - JeepForum.com
post #1 of 8 Old 01-20-2011, 05:36 PM Thread Starter
stefans94SE
When i go around corners it either sounds like my steering box is popping or clunking and i can't figure it out.
stefans94SE is offline
post #2 of 8 Old 01-20-2011, 05:52 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
You are going to have to get a friend to move the steering wheel while you look under and try to find out what it is. Could be steering box, loose shackles, loose u-bolts, tie rod ends, there are lots of things that can wear.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 8 Old 01-20-2011, 07:25 PM
Mark05059
could be the frame flexing at the steering box and getting ready to break off... ask me how I know..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 8 Old 01-20-2011, 07:34 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I think the little universal joints on the lower steering shaft would be the first thing to check. The U joints are not available. The entire shaft has to be replaced. But, the other possibbilities already mentioned are quite possible also.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #5 of 8 Old 01-20-2011, 07:46 PM
MattysWrangler
LOL Come see all my YJ's, first off......... Check the frame around the steering box. I see soemone else knows from experience as well! LOL
MattysWrangler is offline
post #6 of 8 Old 01-20-2011, 07:50 PM
93jeepyj
I had that happen sometimes especially when it was wet out. Ended up being one of the front springs shifting (millitary wrap).
93jeepyj is offline
post #7 of 8 Old 01-20-2011, 08:16 PM
moonshinefuel
Have someone watch the steering as it is steered side to side to have the noise occur as you watch from the front. Agree with 93jeepyj. Watch the spring loop in the bushing. What can happen is the grease dries up in the bushing, and it starts to grip the collar, then stops sliding, but pops and moves under pressure when steering. This is something I have had personal experience with, and have had happen to me. It makes quite a popping noise, and you can feel the shift a little sometimes after the pop. watch the bushings real close when the noise happens, if the spring moves a little at the same time in the bushing, that could very well be what it is. You need to grease the bushings. I have also heard of popping noises from a bad steering dampener, but that has never happened to me personally. But obviously, it could be many things as mentioned.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #8 of 8 Old 01-20-2011, 09:15 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Mine does this to.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
popping noise in back end.. Meep97 TJ Wrangler Technical Forum 1 08-08-2010 04:29 PM
PLEASE HELP!!!! Noise in back sounds like something needs grease. Pyrobee TJ Wrangler Technical Forum 8 06-17-2009 04:42 PM
popping noise when I turn jimG16 TJ Wrangler Technical Forum 8 08-05-2008 03:46 PM
Noise when I turn my steering wheel... TJ-Tera TJ Wrangler Technical Forum 5 01-27-2008 05:53 PM
Popping out of fourth? RockRunner85 TJ Wrangler Technical Forum 9 08-11-2006 05:41 PM
