when i make tight turns in 4x4 my jeep bounces forward! WHY??? - JeepForum.com
post #1 of 4 Old 10-22-2001, 08:33 PM Thread Starter
jerrys yj
okay heres my problem. when i put my 91 yj into fourwheel drive and try to make tight turns it feels as if the jeep is lunging forward and stopping and just wont turn nor
17 year old with a 1991 four banger
-3"RC lift
-32's on the way
-KC's on the windshild
personal quote:"it didnt look that deep dad, i swear!"(first time stuck in mud)
jerrys yj is offline
post #2 of 4 Old 10-22-2001, 08:54 PM
evilpsych
evilpsych's Avatar
dont turn so sharply and you wont have that problem.. or.. turn as sharp has you want and replace U-joints and axles often.. it's your choice..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 4 Old 10-24-2001, 05:45 AM
Atropine
Atropine's Avatar
You have 4 wheels trying to move forward at the same time instead of 2. Also keep in mine that these are your turning wheels too. The only vehicles that wont do this are AWD systems that are designed for full time 4WD.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #4 of 4 Old 10-24-2001, 01:45 PM
cooksterdog
Ok, if your jeep is in 4x4, it is trying to drive BOTH front wheels straight ahead. If you remember, a diffential is supposed to let one wheel move farther, and faster than the other when going around a corner. BUT in 4x4 the diffs work against each other, in that they drive both wheel straight. If you are trying to use 4x4 on hard pavement, or even hard dirt, you are going to rip out some hardware! Even the little bit of slip you get in dirt is enough to let the tires slip and not get bound up. DO NOT USE 4x4 ON PAVEMENT!!! It WILL break your front end or spider gears!
steve and cookie
cooksterdog is offline
One turns forward, the other back crosschecker YJ Wrangler Technical Forum 4 03-13-2007 01:17 PM
Tires rub on tight turns. Jeep Guy 5 TJ Wrangler Technical Forum 7 03-08-2007 09:34 PM
Wheels rub when i make tight turns.... Danlawson TJ Wrangler Technical Forum 11 01-22-2005 09:02 AM
*POP* going on in tight turns htownjeep TJ Wrangler Technical Forum 13 11-24-2004 08:45 AM
when i make tight turns in 4x4 my jeep bounces forward! WHY??? jerrys yj YJ Wrangler Technical Forum 3 10-23-2001 01:11 PM
