When driving jeep does not hold idle. Rpms just drop and Jeep stalls - JeepForum.com
post #1 of 10 Old 02-06-2010, 04:02 PM Thread Starter
myoung
any ideas?
its a 4 cyl. wrangler. manual trans.
myoung is offline
post #2 of 10 Old 02-07-2010, 10:35 AM
YJdad
gonna need more information than that. Does it stall at idle? Is it stalling out while your driving? How long is it running before it stalls? Engine up to temp? Check engine light? What codes are you getting? Did you mow your grass that day? What does it idle at? stock motor? Fill out your profile so we can better help you out.
94' YJ Stock 2.5L -
/ BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline
post #3 of 10 Old 02-07-2010, 10:40 AM
bigbelman2009
hahahahaha
but yeah when exactly is it stalling out?
bigbelman2009 is offline
post #4 of 10 Old 02-07-2010, 10:59 AM
jaycal3
Based on the lack of info this may not apply... but my last Jeep had a carburetor and it behaved the same way - it was a vacuum issue. It was fine when going at a steady pace but at every light it would stall out.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #5 of 10 Old 02-07-2010, 01:19 PM Thread Starter
myoung
No it does not stall at idle. I can turn it on and it keeps running. As soon as I start driving it stalls out. If i put my foot on the clutch and the RPMs go down it will just stall. I have to keep my foot on the gas when I pull up to a stop sign or something. It will stall out at idle after driving. Engine is up to temp. No CEL. Yes stock motor.
Thanks!
myoung is offline
post #6 of 10 Old 02-07-2010, 01:20 PM Thread Starter
myoung
It's fuel injected. no carb.
myoung is offline
post #7 of 10 Old 02-07-2010, 03:57 PM
MJMPC
Fill out your jeep profile you will get more and better answers.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 10 Old 02-07-2010, 07:21 PM
jbars
might need new tps??
jbars
94 yj
hoosierland
jbars is offline
post #9 of 10 Old 02-26-2010, 08:24 PM
Mediarocker
1993 XJ Cherokee
whenever my TPS is wet this happens...just throwing this out there.
1993 Jeep Cherokee Country - 4.0L I6 (Junkyard Edition!) | Aisin AW4 (Using ATF+4)
Mediarocker is offline
post #10 of 10 Old 02-26-2010, 10:22 PM
93TRJeep
I had a similar problem a month ago and it turned out that i had a rusted distributer cap terminal and wire. I replaced them both and have not had problem since.
Chris
1993 YJ Wrangler Sport - I6 4.0, Auto, D30/D35 3.07's, KC Lights (Windshield & Front Bumper on Pipes, Cooler Racks w/ Rod holders, TJ filler mod,
1995 Chevy Cavalier - DD- I4 2.2L Auto POS (current crushed wherabouts unknown)
1967 Ford Mustang Coupe - 289 V8 w/4bbl Edelbrock Carb, completely restored
93TRJeep is offline
Engine stalls at idle & while driving tries to stall, but doesn't.... No CEL. Ideas?? mtngoat TJ Wrangler Technical Forum 10 08-09-2013 04:57 PM
Jeep 'almost' stalls when driving fjmd3 YJ Wrangler Technical Forum 15 03-25-2009 03:17 PM
4.0 stalls occansionally when RPMs drop quickly Chad184 TJ Wrangler Technical Forum 4 10-10-2008 01:54 AM
JEEP 2.5 stalls after less than a minute or idling or driving, fuel stops spraying Big-n-Broke-YJ YJ Wrangler Technical Forum 26 02-24-2006 08:13 AM
jeep stalls after driving long distances .. help Pizzaboy04 TJ Wrangler Technical Forum 9 01-22-2006 09:35 AM
