-   -   When driving jeep does not hold idle. Rpms just drop and Jeep stalls (http://www.jeepforum.com/forum/f12/when-driving-jeep-does-not-hold-idle-rpms-just-drop-jeep-stalls-965413/)
myoung 02-06-2010 03:02 PM
any ideas?
its a 4 cyl. wrangler. manual trans.
YJdad 02-07-2010 09:35 AM
gonna need more information than that. Does it stall at idle? Is it stalling out while your driving? How long is it running before it stalls? Engine up to temp? Check engine light? What codes are you getting? Did you mow your grass that day? What does it idle at? stock motor? Fill out your profile so we can better help you out.
bigbelman2009 02-07-2010 09:40 AM
hahahahaha:rofl:
but yeah when exactly is it stalling out?
jaycal3 02-07-2010 09:59 AM
Based on the lack of info this may not apply... but my last Jeep had a carburetor and it behaved the same way - it was a vacuum issue. It was fine when going at a steady pace but at every light it would stall out.
myoung 02-07-2010 12:19 PM
No it does not stall at idle. I can turn it on and it keeps running. As soon as I start driving it stalls out. If i put my foot on the clutch and the RPMs go down it will just stall. I have to keep my foot on the gas when I pull up to a stop sign or something. It will stall out at idle after driving. Engine is up to temp. No CEL. Yes stock motor.
Thanks!
myoung 02-07-2010 12:20 PM
It's fuel injected. no carb.
MJMPC 02-07-2010 02:57 PM
Fill out your jeep profile you will get more and better answers.
jbars 02-07-2010 06:21 PM
might need new tps??
Mediarocker 02-26-2010 07:24 PM
whenever my TPS is wet this happens...just throwing this out there.:wave:
93TRJeep 02-26-2010 09:22 PM
I had a similar problem a month ago and it turned out that i had a rusted distributer cap terminal and wire. I replaced them both and have not had problem since.
Chris
The time now is 01:13 PM.
