When did Jeep change the antenna mast? - Page 3 - JeepForum.com
post #31 of 45 Old 01-08-2014, 07:42 PM
superj
How are tj antennas mounted?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #32 of 45 Old 01-08-2014, 07:48 PM
superj
Never mind, same single point as the parts manual shows for the yj
superj is offline
post #33 of 45 Old 01-08-2014, 08:00 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Originally Posted by superj View Post
If it was a factory item, I believe it would show in the manual. I am not the original owner of my 87 and my wife was not the original owner of her 93 but both list am/FM stereos on the build sheets so I know they are factory. And when I had to replace them since both were snapped off when we purchased them, a quick search on morris and quadratech showed the same single mount, three screw antenna and mount.
I understand about odd ball parts and differing options but I would believe the build sheet and parts manual
Yes mine is the 3 screw mount but it also has a single screw "retainer" above it.
YJ 350TPI NV4500 (D60 14BFF in process)
87TPIYJ is offline
post #34 of 45 Old 01-08-2014, 10:40 PM
brzehentmaier
brzehentmaier's Avatar
Coincidentally, a friend just came through for me. In case anyone is interested, Amazon carries this antenna set-up (Metra 44-UP58):
Thanks for the link, mine broke this weekend brushing the snow off.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #35 of 45 Old 02-05-2014, 01:40 PM
Matt The Hammer
TJs had a round port that the radio antenna was mounted to. In vehicles made without a radio and antenna (still optional on TJs), Jeep installed a filler in the hole like this:
TJ with factory antenna:
Also - here is a Jeep stock photo of a YJ with an antenna. You can see it has the mount as posted earlier from the OEM parts catalog.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #36 of 45 Old 02-05-2014, 01:50 PM
Matt The Hammer
Another parts catalog showing OEM antennas:
2013 JKU
1995 YJ
post #37 of 45 Old 02-05-2014, 02:31 PM
tr21triton
my brothers 91 had the same one that's on the red one in the first pic. as a quick fix we found a driveway reflector on a aluminum rod at wallyworld for $0.98 and knocked the reflector off it and stuck the rod it in the hole with a few wraps of tape to stop it from rattling. worked great until he bought the one from amazon.
tr21triton is offline
post #38 of 45 Old 02-05-2014, 06:58 PM
bigbossd1030
95 YJ.
Mine is like the last one on this page. Or the black jeep on page 1.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #39 of 45 Old 02-05-2014, 07:45 PM
panaceabeachbum
I just looked at another 87 and it has the 2 point mount like pic one on the first page
panaceabeachbum is offline
post #40 of 45 Old 02-05-2014, 08:45 PM
brzehentmaier
Finally purchased it from amazon last week and works great. Took about 10 min. to install and that's with stopping to have a beer. The guy on amazon has only a couple left.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #41 of 45 Old 02-05-2014, 09:22 PM
deathtrap
I'm curious, has anyone with the odd-ball 2 point set up checked their build sheet to see if it lists a factory installed radio?
deathtrap is offline
post #42 of 45 Old 02-06-2014, 05:36 PM
panaceabeachbum
I did today and mine was shipped no radio so antenna must have been added at the dealer
post #43 of 45 Old 02-06-2014, 09:55 PM
deathtrap
Yep that should give us the answer whether or not these are factory equipment.
post #44 of 45 Old 02-07-2014, 05:49 AM
superj
thats why i commented my 87 and my wife's 93 had radios on the build sheet so i knew our single point where factory installed. that sahara above looks identical to the 93 we had
superj is offline
post #45 of 45 Old 02-07-2014, 06:39 AM
DustyGeneral
My '93 has the second style antenna, though the mounting spot on the body is different. Mine is mounted lower and more towards the front, on the actual body panel, not on the triangle piece as the pic you provided shows.
DustyGeneral is offline
Jeep wrangler antenna Problem help!! Zjs21 TJ Wrangler Technical Forum 11 06-01-2015 04:35 PM
Where to buy am/fm jeep antenna? mideerhunter YJ Wrangler Technical Forum 14 11-27-2012 10:25 AM
Black Antenna mast? XpensiveWino JK Wrangler Technical Forum 11 09-08-2007 12:04 PM
short antenna for jeep acat YJ Wrangler Technical Forum 0 06-15-2007 10:44 AM
Wipers at 1/2 mast Wranglerguy YJ Wrangler Technical Forum 9 04-17-2007 03:58 PM
