When did Jeep change the antenna mast? - JeepForum.com
post #1 of 45 Old 05-28-2012, 04:19 PM Thread Starter
drew2000
drew2000's Avatar
Hey Guys,
I have been trying to find a replacement antenna mast for my 1994 YJ, the old mast snapped off, although the brackets are fine. My Jeep has the double plastic bracket style mount, and the mast itself has a screw that goes through the bottom and ties the metal mast into the plastic bracket.
I have searched the parts catalogs for the right mast, but can't find it anywhere. All the stores and eBay seem to stock the CJ-style single mount (even for my year, 1994).
Does anyone know any more about when they changed?
Here are some pictures I stole from a similar thread, the first one is my style (note the two plastic mounts, upper and lower). The second is the style that everyone seems to sell.
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #2 of 45 Old 05-28-2012, 04:22 PM
stroked250
Your mount is not OEM.
stroked250 is offline
post #3 of 45 Old 05-28-2012, 04:25 PM Thread Starter
drew2000
drew2000's Avatar
Hmmmmm, strange. I have had 2 1994's and they both had this style mast. Maybe it was a dealer installed option?
Drew
drew2000 is offline
post #4 of 45 Old 05-28-2012, 04:41 PM
Jax89Jeeper
Drew
Nope there was no dealer option for a different antenna.... It is a side mount boat antenna I believe, and they are pretty easy to find online.
Jax89Jeeper is offline
post #5 of 45 Old 05-28-2012, 05:40 PM
panaceabeachbum
thats odd, my 1989 came from the dealer with the same antenna setup in Drews first pic and the replacement i ordered from Morris is a very similar 2 point mount. the original was collapsable , the new one is not.
panaceabeachbum is offline
post #6 of 45 Old 05-28-2012, 06:06 PM Thread Starter
drew2000
drew2000's Avatar
panaceabeachbum,
That's good to know that your 1989 came with this same setup. Both of my 94's have had this setup, and the red pic (which is not my jeep) has it too.
If I can actually find someone who carries the mast, it is probably a 10 or 20$ part. I have to spend hours searching for it though
Drew
drew2000 is offline
post #7 of 45 Old 05-28-2012, 07:24 PM
panaceabeachbum
I just looked at the one I recieved from morris and its single point like the second pic, I have the remnants of my original and its a two point mount like the first one.
My jeep came with a non factory stereo and dealer added air so maybe the antenna was added at the dealership
post #8 of 45 Old 05-28-2012, 08:27 PM
evanjeep
2011 WK
Mine is a 88 and it looks like tge 2nd
evanjeep is offline
post #9 of 45 Old 05-28-2012, 08:35 PM
gunshw301
I could see jeep running out of parts for production. A quick replacement would get them rolling again. So I suspect there could be a few odd balls out there. You see it in the 87s and 95s typically with the start and stop of model years.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #10 of 45 Old 05-28-2012, 08:41 PM
Mickey_Mouse
2013 KK Liberty
Mickey_Mouse is offline
post #11 of 45 Old 05-28-2012, 08:46 PM
Jax89Jeeper
Originally Posted by Mickey_Mouse
As I already said. . Thanks for posting the link.
post #12 of 45 Old 05-29-2012, 03:46 AM Thread Starter
drew2000
drew2000's Avatar
Thanks for the link, but that is just not it. Maybe they did use a boat antenna, but it is clear now that Chrysler had 2 antenna parts used in different years. Maybe the two-piece style was a boat part, but I have not been able to find any boat parts that look even close.
Maybe Chrysler bought up 100,000 boat antennas and then used them as spares... The two-piece style seems to be widely distributed over the years (at least 89 through 94), but clearly only on a minority of Jeeps.
Thanks
Drew
drew2000 is offline
post #13 of 45 Old 05-29-2012, 04:33 AM
ashnken
my 91 and 95 yjs both have thevsingle type mount.
ashnken is offline
post #14 of 45 Old 05-29-2012, 07:10 AM
Mickey_Mouse
2013 KK Liberty
I have a body plug where the antenna goes for now. get a wireless antenna.
http://www.ebay.com/itm/Hidden-Stere...3a4d28&vxp=mtr
http://www.ebay.com/itm/Hot-Rod-Rat-...0c6ced&vxp=mtr : fit it on the roll bar.
post #15 of 45 Old 05-29-2012, 07:51 AM
GrantYJ
FWIW, my '92 has the "2 point" style (at least since 1999).
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
Jeep wrangler antenna Problem help!! Zjs21 TJ Wrangler Technical Forum 11 06-01-2015 03:35 PM
Where to buy am/fm jeep antenna? mideerhunter YJ Wrangler Technical Forum 14 11-27-2012 09:25 AM
Black Antenna mast? XpensiveWino JK Wrangler Technical Forum 11 09-08-2007 11:04 AM
short antenna for jeep acat YJ Wrangler Technical Forum 0 06-15-2007 09:44 AM
Wipers at 1/2 mast Wranglerguy YJ Wrangler Technical Forum 9 04-17-2007 02:58 PM
