Wheel won't come off... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Wheel won't come off...
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-04-2013, 07:43 PM   #16
ROWA
ROWA's Avatar
If you ever get the wheel off, you need to take the axle out and check the C-clip and cross-pin. Beating on the center hub can damage the part's inside of your differential.
I would place a long block of wood under the axle and chock the wheel on the other side and front, pop the clutch in first and reverse a few times to break it free.
Good luck.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 08:22 PM   #17
SeanB95YJ
Originally Posted by fratis View Post
Originally Posted by SeanB95YJ
well since there's no studs in there I'd try the following
DO THIS ONLY IN YOUR DRIVEWAY - NOT IN THE STREET:
1- put in reverse, go a little and SLAM on the brakes... then drive forward a bit and SLAM on the brakes
2- block wheels, jack up and see if the wheel is any looser
repeat step 1 as necessary, as eventually it'll break the rust bond and spin on the hub
good luck
Originally Posted by Longview
... I don't have any breaks I'm replaces all the lines. I knew that trik but I can't stop LOL
E-brake?
[FONT="Comic Sans MS"][COLOR="Blue"]Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
[/COLOR] [COLOR="Red"]swap/build thread: [url]http://www.jeepforum.com/forum/f22/after-almost-4-years-finally-my-own-build-swap-thread-1542284/[/url][/COLOR][/FONT]
SeanB95YJ is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 08:46 PM   #18
bpounds
bpounds's Avatar
I really don't get beating on the end of the axle. Generally you want to beat the wheel outward, not the Jeep inward.
But I also understand frustration. Time to walk away for the day.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 10:09 PM   #19
scramblered
When I could not remove the wheels on mine I had to get creative. For the fronts I jacked up the wheel a little and a foot long piece of 2X4 was placed between the frame and the front of the tire. Then turning the steering wheel into the 2x4 the wheel popped right off. For the rears I again jacked up the wheel with a floor jack and then using my high lift and a piece of 4x4. I jacked against the wheel and it also popped off. Good luck, Dave.
"Not all who wander are lost."
scramblered is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 11:11 PM   #20
Longview
Originally Posted by SeanB95YJ View Post
E-brake?
Barely. Lol
Longview is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 11:59 PM   #21
bigbossd1030
Like most have said above, now that the edges of that hub are all jacked, that rim won't come off anyway now. I'm betting its acting like a wedge and holding that rim on there for good now. Is it not possible to just pull the diff cover and drop the pin and c clip and pull the shaft and hub and drum all at the same time? If this can be done, I would try and find one in the JY to grab a new shaft out of. Then I could do anything I need to in order to get that rim off of the hub. Just an idea if you have the funds for that.
Sent from my iPhone, probably because I am bored at work.
[COLOR="DarkGreen"]/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)[/COLOR]
[COLOR="Blue"]OFFICIAL JEEPER[/COLOR]
[COLOR="Red"]Any Jeepers in Edmonton, AB
I am on channel 33.[/COLOR]
I live, I ride, I am JEEP.
bigbossd1030 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 07:35 PM   #22
Gausswave
Got enough room to stick a jack between the frame ( or springs ) and the wheel?
Gausswave is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 07:48 PM   #23
GrantYJ
Wow... That's a mess.
Please do not move this vehicle in this condition. As said earlier, put it on a jack stand, but just barely clear the ground with it (an inch or less).
Once this is done, use an angle grinder with a flap disc (not a grinder) 36 grit will cut just as fast, but if you're careful, it shouldn't dig like a grinder will. Go around the outside of the "beaten and abused" end of your axle (the metal will come off much faster than you think). Once it's relatively flush (you won't be able to get it all the way back to the wheel), put a short piece of 4x4 lumber against the bottom of the tire (yes, on the outside) and smack the %^&* out of it with a sledge hammer.
Due to the leverage, hitting on the outside is just as effective as hitting from the inside, but from the outside, you can actually get a good swing on it. Once it starts to work loose, just spin it a quarter turn and whack it some more. It'll come off, but it isn't going to be a fun evening.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 08:37 PM   #24
Longview
I cut it off. I heated it till it was red hot and it still wouldn't budge. I heated it and shot water at it I tried everything. So I cut it off.
Unread 08-06-2013, 09:18 PM   #25
jokerchief462
That is some serious STUCK!!!
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
[COLOR="Blue"][B]AF Jeep Club Tail #184[/B][/COLOR]
jokerchief462 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 09:52 PM   #26
Longview
We were workin at it for at least two hours before I said screw it. Ill just buy a new jeep wheel at a junk yard. Werid thing was, that the other tires all came off without a hammer or kick or punch. Only that tire was stuck!
Unread 08-06-2013, 09:58 PM   #27
bigbossd1030
Copper coat next time maybe. I always do.
l----L-[]lllllll[]-
Unread 08-06-2013, 10:09 PM   #28
Longview
Copper coat? I was just gona get some anti seise grease.
Unread 08-06-2013, 10:10 PM   #29
bigbossd1030
Same crap different pile. I just use copper coat cuz it's what I had at the time.
l----L-[]lllllll[]-
Unread 08-06-2013, 11:18 PM   #30
102joe
One good thing about CA. is relatively no rust . I've never even heard of that befor . I have more trouble keeping my wheels on
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline   Reply With Quote Quick reply to this message
