Wheel spacers - JeepForum.com
post #1 of 9 Old 02-03-2013, 07:15 PM Thread Starter
Labhound
Wheel spacers
I posted this in the wheel tire section with no response and googled it with nothing about this, so..
I put spacers on today and noticed on the rear the wheel studs don't leave much room, threads, for the spacer lugs, I didn't like it so I left the rear spacers off. The fronts have more threads though, yes, the front wheels stick out a little bit wider now, but they don't rub!!
Has anyone had the same problem? or are longer studs a good idea?
Labhound is offline
post #2 of 9 Old 02-03-2013, 07:18 PM
WhiteOut
WhiteOut's Avatar
You just used slip on spacers?
You should be using the type that bolt to the hub and have studs built in for the wheel to bolt to, the slip on ones are unsafe for the exact reason you found out.
WhiteOut is offline
post #3 of 9 Old 02-03-2013, 08:25 PM Thread Starter
Labhound
Yeah they are the bolt on, but, not much of the Jeep's factory studs come through for them to bolt to. They will bolt on but I don't like how it looks with only half of
the nut on there.
Labhound is offline
post #4 of 9 Old 02-03-2013, 10:08 PM
tonymartin
Are you sure they're seated all the way on with no interferance? They should sit enough for you to get at least the full nut on.
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #5 of 9 Old 02-03-2013, 10:18 PM
tonymartin
Also, which brand are you using and what is the actual spacer size?
post #6 of 9 Old 02-04-2013, 04:37 AM Thread Starter
Labhound
They're 1.5" and some off brand.
Labhound is offline
post #7 of 9 Old 02-04-2013, 07:20 AM
Mark05059
Im betting the center hole isnt seating correctly...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 9 Old 02-04-2013, 07:37 PM Thread Starter
Labhound
I sort of solved that issue.... I just took them off..
Anyone need them...?
Labhound is offline
post #9 of 9 Old 02-05-2013, 02:55 AM
Taylor_44
I could use some wheel spacers. How much you want for them shipped to 85283?
Taylor_44 is offline
