Wheel question - JeepForum.com
post #1 of 2 Old 12-23-2001, 10:44 PM Thread Starter
Keymaster
Keymaster's Avatar
Wheel question
I have two questions actually...about wheels and tires....I have 15 x 8 wheels with new 31 x 10.5 tires right now on stock suspension. I'm gonna install a 3 inch suspension lift early next year and I'll also be looking to upgrade those wheels after that. Since I just bought my tires I'll be looking to just upgrade the wheels after the lift is installed. In the future I want to run a tire a little bigger and wider. So now to the questions...
1. Would it be okay to get 15 x 10 wheels to compliment my 31 x 10.5 inch tires for now? and
2. What is a good alternative size to a 33 x 12.5 tire? I would like to go around this height (not any higher), but I would like something a little wider.
Just so you know, a majority of my off-roading will be on the sand and not on the rocks. So that's why I want to go with a nice, wide tire. I know it's not smart to run a wheel the same width as the tire because you can damage the wheel but I figure sand shouldn't do much damage. Oh, and MERRY CHRISTMAS!!
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #2 of 2 Old 12-24-2001, 11:09 AM
RodeoRob
RodeoRob's Avatar
I wouldn't go with 15x10's for your application. Yes, you could run a 10.50" wide tire on them, but don't plan on airing them down at all! you'll definitely be asking to loose a bead. Even with a 12.50" tire, there still isn't enough difference IMO in width to air down substainally without risk of loosing a bead.
You indicated a lot of your wheelin will be done in the sand... you'll be looking to run a really low tire pressure to get as much traction as you can... probably somewhere down around 5 psi. I'd be looking at a 15x8. The narrower rim will keep more pressure on the bead allowing you to air down further for the sand.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
Gear Question and Tire/Wheel Question brjeep TJ Wrangler Technical Forum 3 01-19-2010 09:09 AM
Wheel question md_rubi JK Wrangler Technical Forum 2 08-15-2009 08:30 PM
Wheel Question TA-YJ YJ Wrangler Technical Forum 3 02-14-2009 04:17 PM
Wheel Question.. ZX14Rider JK Wrangler Technical Forum 2 05-26-2008 06:00 AM
Wheel Question YJsoldier YJ Wrangler Technical Forum 4 12-31-2005 08:07 AM
