whats wrong with my jeep? - JeepForum.com
post #1 of 13 Old 08-22-2005, 06:27 PM Thread Starter
cr125racer
i have 1990 jeep wrangler yj with the 2.5L, and it will not start and stay running.
when we try to start it, it turns over and everythingike normal, it has great spark, 15LBS feul preasure, all the cylinders have 130LBS compression. we checked for anything to be wet. it ran fine one week ago, then we parked it and it sat for 5 days, then i went to start it up and it wouldnt stay running , you have to keep giving it gas to keep it running. it will not idle. did anybody ever experience these problems or have any answers. thanks in advance.
cr125racer is offline
post #2 of 13 Old 08-22-2005, 06:45 PM
Alfons
Some possibilities:
1. Vacuum leak - broken vacuum line.
2. Failed or malfunctioning emission component - EGR or PCV.
3. Leaky manifold (intake)
4. Timing chain
5. Ignition timing
6. Choke
Alfons is offline
post #3 of 13 Old 08-22-2005, 07:27 PM
Why J?
Why J?'s Avatar
tps sensor took a crap, bad o2 sensor, try unpluging it.
Why J? is offline
post #4 of 13 Old 08-22-2005, 11:25 PM
mat626
yea- sounds like an o2 sensor- mine did the same thing
mat626 is offline
post #5 of 13 Old 08-23-2005, 03:23 AM
RB_
02 sensor would also be my first guess from what you describe
92 Jeep Renegade
4.0 HO 5spd
work in progress
"Ugly Jeep Rescue League" Member #1
RB_ is offline
post #6 of 13 Old 08-23-2005, 05:11 AM
drew2000
drew2000's Avatar
15 PSI on the fuel pressure is way low, should be around 35-45 at idle IIRC.
<edit>look for a weak fuel pump or clogged fuel filter or bent fuel lines<edit>
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #7 of 13 Old 08-23-2005, 05:47 AM
Surpra76d
My Jeep runs with the o2 sensor unplugged...so I would guess that its not the o2..... it runs like crap but it still would run.
Surpra76d is offline
post #8 of 13 Old 08-23-2005, 06:35 AM
wolf3902
Drew
yup...low fuel pressure
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #9 of 13 Old 08-23-2005, 06:26 PM Thread Starter
cr125racer
the haynes manual calls for 15lbs of fuel preasure for the TBI. do u thinks thats still to low because it can be adjusted withe preasure regulator,
post #10 of 13 Old 08-23-2005, 06:40 PM
drew2000
drew2000's Avatar
Ohhhh it's TBI, if that is spec than that's ok. I thought it was MPI.
Drew
drew2000 is offline
post #11 of 13 Old 08-23-2005, 09:24 PM
Mr. Notorious
Does the TBI have an IAC? Idle air control motor? Mine did the same thing and the IAC was at fault. Mine is bolted to the throttle body on the 4.0L. Same thing, mine was sitting for a good week for me working on the clutch and then when I was all done she couldn't idle. I drowned the IAC in intake cleaner and drove her for awhile and she cleaned right out.
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline
post #12 of 13 Old 01-03-2013, 12:14 AM
alan777
can anyone help i have a 1993 jeep grand Cherokee limited 5.2.l it runs and sounds great but is using a ton of gas like 7 mpg gas in oil should be rings right? But all cylinders 150 psi. fuel pressure 35 psi no vacuum leaks has new coil new crankshaft position sensor new alternator good batt new starter new fuel pump does not foul plugs i haven't got to use my jeep in a year any help would be appreciated
alan777 is offline
post #13 of 13 Old 01-03-2013, 12:19 AM
Drix
Yah post it in the grande cherokee forum.
Off hand though get your cat looked at.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
whats wrong with my jeep SWAMPED YJ Wrangler Technical Forum 4 08-31-2007 03:26 PM
Whats wrong with my jeep?! ClemsonRocks YJ Wrangler Technical Forum 4 12-01-2006 02:29 PM
whats wrong with my jeep? hauganater2315 TJ Wrangler Technical Forum 9 06-12-2006 08:57 PM
whats wrong with your jeep 89_Sahara YJ Wrangler Technical Forum 42 12-02-2005 06:22 AM
NOW whats wrong with my Jeep!!! Parabola YJ Wrangler Technical Forum 5 04-03-2004 08:53 AM
