What's the voltage ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What's the voltage ?
Borla Exhaust presents "Climber" at EJSTactical Recovery Equipment Soft Shackles!!!Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 04-04-2013, 06:36 PM   #1
Ericgormsenjr
1987 YJ Wrangler
What should the voltage reading be at the injector on an '87 2.5 with TBI. Mine reads 3.57 is this correct?
Ericgormsenjr is offline   Reply With Quote Quick reply to this message
Unread 04-04-2013, 07:18 PM   #2
Que89YJ
You should have 12 volts. You need to test it with your meter ground to the body our negative battery.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2013, 06:10 PM   #3
Ericgormsenjr
1987 YJ Wrangler
Thanks que
Just saw your info on the voltage. Would you have any idea why it would be so low? I rechecked it as you said. One side I get no reading and the other I get 3.60 volts. If it is a ground, where should I start looking? So far I've replaced the external in line fuel filter, injector (which I took off and put old one back on b/c it did exact same thing) blew out return line and all ports on TB. I found a used TB complete on eBay and ordered it and am just waiting for it to install. But if its voltage issue I don't know where to look. Thank you for any knowledge you can instill on me to solve this.
Unread 04-05-2013, 07:00 PM   #4
Que89YJ
Do a meter check by measuring the battery. Check the voltage with just ignition on not running. Make site your meter is set to dc voltage.
Unread 04-05-2013, 07:01 PM   #5
Que89YJ
What is the problem?
Unread 04-05-2013, 07:12 PM   #6
Que89YJ
I can hook you up with the link for both the fuel pressure and the service manual tomorrow. I have them on my laptop. pm me and remind me tomorrow morning. I am on my cell.
Unread 04-05-2013, 08:11 PM   #7
jsawduste
2006 YJ Wrangler
You sure about that ? Are we talking the 5 volt reference that is common to each injector or the signal from the ECM ?
D, I owe you a call and I think something else but for the life of me I cannot recall what it was............
jsawduste is offline   Reply With Quote Quick reply to this message
Unread 04-05-2013, 08:52 PM   #8
Que89YJ
Injectors feed off the asd relay. Not the nice pdc setup on the obd1 but yes they are 12
Unread 04-05-2013, 09:24 PM   #9
jsawduste
2006 YJ Wrangler
Got it, thanks
Unread 04-06-2013, 07:43 AM   #10
Ericgormsenjr
1987 YJ Wrangler
Voltage/Fuel and who knows
Que,
I checked the voltage on the throttle body injector and when grounded to frame get a 3.6 reading with only ignition on not running. When I check across injector connection I get 3.57. Can I run a 12v feed from ignition and splice into injector connection?
Unread 04-06-2013, 11:26 AM   #11
Que89YJ
did you check the battery voltage to make sure the meter is working?
Unread 04-06-2013, 02:51 PM   #12
Ericgormsenjr
1987 YJ Wrangler
reply to Que
Yes, battery voltage is 12.6v. Could I run a 12v source from on position and tap into injector connection?
