whats slapping under my jeep after my lift install??? - JeepForum.com
post #1 of 12 Old 06-12-2004, 06:32 PM Thread Starter
smogmatt
Ok so I finished my 2.5 RE standard lift I installed everything, axle shims, t-case lowering kit.
I have had it for a couple of weeks
I love it....but when I go over bumps on the road with any speed it feels like the transfercase or tranny is slapping up against the body. I checked out the under side. I cant see anywhere its hitting. I did notice I have only got about an inch space between the t-case and the driveshaft. so I think the t-case and driveshaft are slamming next to each other.
I don't have any touble with vibes at all. just this.
I guess my question is is this normal? should I remove the t-case lowering kit and/or the axle shims? Or what else could I do?
TIA guys
smogmatt is offline
post #2 of 12 Old 06-12-2004, 06:37 PM Thread Starter
smogmatt
oh its a 4 banger stick shift
RED 92 4-banger 2.5 RE Lift, Kumho 31x11.5 Ventures M/T. Black steelies, Herc-ed, Duomax muffler and Homemade 40mm ammo box console and speaker boxes.... and some other stuff
smogmatt is offline
post #3 of 12 Old 06-13-2004, 12:37 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Could be a tranny mount or loose exhaust.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #4 of 12 Old 06-13-2004, 12:01 PM Thread Starter
smogmatt
just replaced the muffler and cat so thats solid.
I will check the trannie mount....... so could it be the driveshaft slamming in to the transfercase?
maybe I will uninstall the t-case lowering kit and see what I get
smogmatt is offline
post #5 of 12 Old 06-13-2004, 02:42 PM
surfzup2k
surfzup2k's Avatar
I would bet it is the slip yoke sliding all the way onto the output shaft of the t-case. I would take the spacers in the skid pan out for sure. All that holds that shaft pulled out wards is a clip. If the skip yoke slams it hard enough, that clip will break and everything in your t-case will be mis-aligned.
1995 YJ 4x4 4.0 5-Speed
35x14.50x15 SS Terdbirds
4" Skyjacker lift
2" hd shackles
locked 8.8 Rearend
4.56's
cut fender flares
pics...
color="white">White Jeep Club Member #112
surfzup2k is offline
post #6 of 12 Old 06-13-2004, 04:22 PM Thread Starter
smogmatt
should I also take off the rear axle shims?? or will removing the lowering kit be enough?
thanks
smogmatt is offline
post #7 of 12 Old 06-13-2004, 06:15 PM
TSEJEEPERS
Leave the shims. Take off the lowering kit and see if you have any vibes. Did the kit come with the shims and the transfer case lowering kit?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 12 Old 06-13-2004, 06:56 PM
BIG KEV
Does that suspension kit come with millitary wrap springs? If it does and you didn't upgrade your shackels it could be your springs slapping against your frame!
Punisher 95 YJ
SOA 103' WB 40" IROKS
Kingpin HP60 / 60 5.13's locked
KORE4x4CUSTOMS.com
BIG KEV is offline
post #9 of 12 Old 06-13-2004, 08:58 PM Thread Starter
smogmatt
the kit did come with the shims and t-case lowering kit (1") I never drove the jeep w/out the shims and lowering kit. I put everything on all at once. I guess I should have gone for a test ride before huh?
the kit did come with miltary wrapped springs, they didn't recommend to upgrade the shackles....thats still on the list of to-dos. the slapping feels more like its right under the driveline. I'll take off the lowering kit and if I still have problems I'll have to look into that.
smogmatt is offline
post #10 of 12 Old 06-17-2004, 11:09 AM
hmk_21
Tell me how it goes...
I just got mine on this past weekend, and I too.. have a 'clanking' sound when it flexes..
however, with the door off, and no top.. i was able to pick up the sound location..
with the stock 'hitch' on my 89yj.. the wrap on the new spring (rear passenger side) was hitting the hitch connection to the frame..
i lost 3/4" of rear shackle movement... at least this is my issue anyways, as i can see fresh skid marks on the metal...
flex test, and and possible hitch removal tonight
89 Yellow YJ Islander 4.2L *decal free*
hmk_21 is offline
post #11 of 12 Old 06-17-2004, 11:16 AM
frank_yj
frank_yj's Avatar
hey smogmatt... our yj had a simular issue... the military wraps were banging on the aftermarket rear bumber... all i did was break out the grinder and grinded the area it was hitting...
HTH
Frank
Wife's = 93 sahara 3" body, 3.5 BDS, 33x12.5 super swamper radials, safari snorkel, rhino liner, steps, body armor.
Me = 1980 CJ5 350/350/300/44 fr/14 bolt rear both locked/38" swampers
frank_yj is offline
post #12 of 12 Old 06-17-2004, 04:27 PM
BIG KEV
I was right! If they are bds you can cut the wrap off untill you get some lift shackels, then when you do just take those two springs to the shop where you bought the lift and tell them that you want a new set. Or at least thats what i did.(I love bds and there warranty)
Punisher 95 YJ
KORE4x4CUSTOMS.com
BIG KEV is offline
Looking to lift. whats spacers? whats block spacer? lift kit? i have a 95 STOCK! gamer0 YJ Wrangler Technical Forum 15 04-12-2009 09:46 PM
whats average labor cost to install 4 inch lift yj bcameron1974 Wrangler General Discussion 5 12-30-2008 01:19 PM
new jeep, whats the lift? cox8338 TJ Wrangler Technical Forum 5 03-01-2008 12:52 AM
whats the easyest lift to install? blk05tj TJ Wrangler Technical Forum 10 10-18-2005 07:21 PM
slapping dave4887 TJ Wrangler Technical Forum 1 02-25-2005 11:57 PM
