whats the problem? - JeepForum.com
post #1 of 3 Old 10-09-2002, 08:34 PM Thread Starter
4wheelinfool
4wheelinfool's Avatar
1980 CJ5
whats the problem?
will someone explain to me what the problem is with my jeep?
i just installed a 4" procomp suspension and put 33x12.5 mud kings on my yj, with zero other mods. I went wheelin yesterday and i found out that i have VERY little flex. I dont understand this? why dont i have any flex? After about 1ft. of flex i get a tire off the ground. What do i need to get the flex i want?
4wheelinfool is offline
post #2 of 3 Old 10-09-2002, 09:25 PM
93jeepyj2.5
93jeepyj2.5's Avatar
I had the same problem when I installed my 3.5" BDS.
What I did to fix the problem was made a set of sway bar disconnects, and I also removed both track bars.
Now my flex is great and I will soon be buying a set of revolvers for the rear.
HTH
Feel free to ask if you have anymore questions.
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline
post #3 of 3 Old 10-09-2002, 09:42 PM
Bob K
Bob K's Avatar
Yeah. I had the same problem when my ProComp 2.5 was first installed. It was damned embarassing getting stuck on level ground after one tire would dig a little sand away and the suspension would not flex enough to keep it in contact. . The ProComp is known to be about the stiffest lift available.
1. Remove at least the rear track bar. Removal of the front track bar is more a matter of individual preference. Quick discos on the sway bar are good too.
2. Loosen up the shackle and spring bolts to the point where the nut spins freely when you turn the bolt. I've had mine like this for nearly three years with no problems of them coming loose. If your concerned you can put on loc-tite or gnarl up the threads with pliers.
3. Spray WD-40 or any kinds of lubricants between the leaves to keep them sliding freely against each other.
4. The good news is that the springs do develop more flex over time. Go out and loosen them up with a lot of off road driving.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
Whats the problem RedWind YJ Wrangler Technical Forum 9 11-02-2008 04:34 PM
3 Distributors in 1 year! Whats the problem MyFirstJeep_93 YJ Wrangler Technical Forum 15 01-15-2008 01:55 PM
my 97 4.0 misses whats most common problem EarnhartBuilt TJ Wrangler Technical Forum 14 02-25-2007 04:40 PM
whats the problem here??? yellowismellow TJ Wrangler Technical Forum 6 11-24-2006 01:37 PM
whats the problem with the d35? KWAG TJ Wrangler Technical Forum 9 08-04-2005 10:18 PM
