What's the name of this part? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What's the name of this part?
Unread 03-26-2013, 04:06 PM   #1
DarthBrooks
What is the name of the five pieces with the rod bearings that are visible? The rebuild kit that I ordered only came with one. Are not all of them necessary?
DarthBrooks is offline   Reply With Quote Quick reply to this message
Unread 03-26-2013, 04:08 PM   #2
DarthBrooks
I only have the short one that's directly in front of the middle pile of synchros. Also, what are those small pieces next to the tube?
Unread 03-26-2013, 05:50 PM   #3
rogerv
rogerv's Avatar
The small pieces are called synchro blocks, the bearings are called cage bearings. Did you get a master rebuild kit or a shortened version?
Look on YouTube under ax-15 rebuild. Will Robinson has a series on rebuilding one. Mean max also has a write up in the forum on rebuilding.
If it's not broke- modify it, so it won't break
rogerv is offline   Reply With Quote Quick reply to this message
Unread 03-27-2013, 01:55 PM   #4
DarthBrooks
It would seem I got the shortened one. I've read Mean Max's thread and it will be very helpful. But are new cage bearings necessary if the old ones work? I guess what I'm trying to say is should I replace them anyway since I have the thing already taken apart?
Unread 03-27-2013, 02:13 PM   #5
rogerv
rogerv's Avatar
If you have the new parts and it's already apart- yes put them in. Have you checked your tolerances yet with feeler gauges ?
Unread 03-27-2013, 02:23 PM   #6
DarthBrooks
No. Please expand?
Unread 03-27-2013, 02:56 PM   #7
rogerv
rogerv's Avatar
PM sent
