What's in my Axle? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What's in my Axle?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-08-2014, 11:33 PM   #16
Jonny92yj
LSD is better then an open diff tho?
Jonny92yj is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 01:30 AM   #17
Anticanman
RIP one good jeeper
Anticanman's Avatar
Depends entirely on the intended application.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 02-09-2014, 10:44 AM   #18
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
FYI, You can rebuild the LSD with new clutch plates for under $150 and stiffen the traction up (adding an extra clutch plate too sometimes). Its not all that bad... Running a 8.8 LSD and works fine The Aussie up front helps a bit also
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495 Build thread. http://www.jeepforum.com/forum/f9/my...hread-2778642/
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
NHfireLJ is offline   Reply With Quote Quick reply to this message
