what's the easiest way to tell if your front axle is still locked up? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > what's the easiest way to tell if your front axle is still locked up?
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 01-21-2002, 07:25 PM   #1
iamthemellowman
I plan on jacking up one tire with the engine off and transfer case shifter in 4wd(after making sure there is no reserve vacuum).. and seeing if i'm able to freely rotate the tire. I imagine there might be an easier alternative.. if so any help would be a great help.
oh and if it is stuck, what are the steps to unstick it?
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline   Reply With Quote Quick reply to this message
Unread 01-21-2002, 08:17 PM   #2
RodeoRob
Get rid of it... those things are prone to failure. Replace it with a Posi-lok or defeat it all together by installing 1-piece shafts.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
robgorrell@yahoo.com - website
RodeoRob is offline   Reply With Quote Quick reply to this message
Unread 01-22-2002, 09:21 PM   #3
YJ boy
Well mellow you can go the post I put up on 01-20-2002 and see how to fix your problem the topic is "Vacuum lines" by YJBOY good luck. but if you really want to check it with out jacking it up you can pull your rear drive shaft off and try it then ??
YJ boy is offline   Reply With Quote Quick reply to this message
Unread 01-24-2002, 06:41 PM   #4
NaeKid
JF Administrator, eh?
NaeKid's Avatar
On YJ's the easiest way to see if the front diff is locked in is to grab the drive shaft and attempt to rotate it in any direction. If it spins, its not locked up.
Make sure that your rig is properly parked when you do this. If the front of your rig is in the air, the drivers side tire might spin with the driveshaft if its locked in.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver 2006 TJ Unlimited, zombie ready as the daily-driver
- - - - - - -TEOTWAWKI- - - - - - -
NaeKid is offline   Reply With Quote Quick reply to this message
