whats the differance 258 and a 4.2 - JeepForum.com
post #1 of 13 Old 04-22-2010, 08:08 PM Thread Starter
Hillbilly Jeep
just as the topic says.. what is the differance? i thought 4.2 and 258 is the same? now im confused...
thanks
Jeremy
Hillbilly Jeep is offline
post #2 of 13 Old 04-22-2010, 08:12 PM
dodger889
They are the same, you are not confused
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 13 Old 04-22-2010, 08:13 PM
ImpactFabWorks
it's the same. Just say 258 when you want to sound like you have a bad *** motor
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #4 of 13 Old 04-22-2010, 08:14 PM
dadstoys2
1987 YJ Wrangler
4.2 is liters
258 is cubic inches
same engine
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #5 of 13 Old 04-22-2010, 08:14 PM
MoparFreak69
One has 3 numbers, the other only 2. One has a decimal point, the other has none. That the only difference to me lol!
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #6 of 13 Old 04-22-2010, 08:17 PM
dadstoys2
1987 YJ Wrangler
yeah it sounds bigger. But my "258" makes gobs of torque
~Rich
post #7 of 13 Old 04-22-2010, 08:17 PM Thread Starter
Hillbilly Jeep
quick reply guys thanks... i know it sounds stupid...i was lookin at clutch kits and they had a 90 yj listed with a 258 and a 90 yj with a 4.2...thats why i was confused... thanks guys
post #8 of 13 Old 04-22-2010, 08:21 PM
Mark05059
same clutch number I would hope??
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #9 of 13 Old 04-22-2010, 08:29 PM
Old4X
1990 CJ7
There are some minor differences, best to check the block numbers near the distributor to be sure what you have. Some of the differences I have run across:
oil filter (4.2 has metric threads)
head bolt sizes differ (some 1/2, some 7/16ths, still not sure which is on which)
different starter
different length pushrods
different flywheels
different pilot bushings
different rocker pivots
Some of these parts may interchange, some don't.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #10 of 13 Old 04-22-2010, 08:38 PM Thread Starter
Hillbilly Jeep
hmmmm interesting... but i wonder why the clutches would be different?
thats good info tho
post #11 of 13 Old 04-22-2010, 10:09 PM
viper21700
Two different clutches... Early model year 1990's had the BA-10 peugot tranny, later models had the Aisin Warner AX-15 trannys installed. Thats why on 1990's you need to verify your tranny before you get a clutch.
viper21700 is offline
post #12 of 13 Old 04-22-2010, 10:13 PM
dadstoys2
1987 YJ Wrangler
Not sure if it matters but when doing the swap from ba10 to ax15 I used my clutch and pressure plate from the ba10.
~Rich
post #13 of 13 Old 04-22-2010, 10:25 PM
ImpactFabWorks
All 1990 YJs had ax-15s. It was in 89 that they used both.
differance in springs? tex4431 TJ Wrangler Technical Forum 3 04-08-2009 12:11 PM
Differance in springs? Macklin96 YJ Wrangler Technical Forum 1 09-07-2008 03:00 PM
Differance in Coils? GIJoe Driver JK Wrangler Technical Forum 2 03-05-2008 06:12 PM
Whats the differance? Jason21 YJ Wrangler Technical Forum 4 05-07-2007 09:01 AM
Whats the differance between a $10 can of 3m undercoating and a $2.50 walmart one? pyro9862 YJ Wrangler Technical Forum 9 02-23-2005 11:44 PM
