What is your oil pressure? - JeepForum.com
post #1 of 5 Old 08-18-2011, 06:09 AM Thread Starter
95Turtle
My oil pressure using the factory gauge always runs around 60-65 psi when cold, then between 40 and 60 when warmed up. In the past I have seen much lower numbers from people on here. Just curious to see what some people are getting. My 4.0 has 162,000 miles on it.
95Turtle is offline
post #2 of 5 Old 08-18-2011, 06:18 AM
little_Jeep
Worthless thread..... OEM gauge sucks ..... replace the gauge, then you will have numbers that actually relate to something to talk about.
little_Jeep is offline
post #3 of 5 Old 08-18-2011, 06:30 AM
oldtime_ironman
65 lbs cold idle, 50 lbs hot highway (about 2200 RPM) 35 lbs hot idle. 2.5 L 4-banger, 152 K miles original engine. I use 10W30 Mobil-1 full synthetic with the Mobil-1 oil filter.
oldtime_ironman is offline
post #4 of 5 Old 08-18-2011, 06:38 AM
dadstoy
I run just over 40 when warm/hot at speed and around 20 at idle.
I have had my 4.0 HOT.....forgot to turn on electric fan once. Took 15 minutes for temp guage to start moving from being pegged all the way right. I am happy to see any oil pressure after that incident.
dadstoy is offline
post #5 of 5 Old 08-18-2011, 06:44 AM Thread Starter
95Turtle
What is your basis for saying the OEM gauge sucks? Mine has always trended well -- higher pressure when cold and higher at high rpms. Either way, it seems like a lot of people have the OEM gauge, so if they all "suck" the same, I don't think it's worthless to compare them.
95Turtle is offline
Gas Tank PRESSURE??? Or Fuel RELIEF PRESSURE?? 915kingwrangler YJ Wrangler Technical Forum 22 03-21-2016 06:33 PM
Need some Genius! Oil Pressure Pump/Switch/Crank Bearings Replaced - Pressure Low??! malo8899 YJ Wrangler Technical Forum 1 05-20-2010 02:32 PM
Possible to convert '03-'06 oil pressure gauge to display actual oil pressure? Night Wolf TJ Wrangler Technical Forum 40 05-03-2010 11:48 AM
Oil pressure = 100 SkullTripper YJ Wrangler Technical Forum 5 03-04-2010 08:24 PM
oil pressure??? 98tjproject TJ Wrangler Technical Forum 8 02-28-2010 07:53 AM
