What is wrong with my rear axle? - JeepForum.com
post #1 of 11 Old 10-24-2011, 03:10 PM Thread Starter
TIMXJ
I have seen a ton of pictures of YJ's on here, both stock and modified. I look at the rear wheels on my 95 YJ and they sit forward in the fenderwells. I have 31s with a 1" BL and the tires will occassionally rub at the frontside of the fender flair. If you look at the way they sit under the fender flair they seem to sit forward...almost like the axle is forward...is this possible?IMy last YJ was an 89 and I look at pics of it and the 31s were centered under the fender flair..
Your thoughts would be appreciated
Cheers
Tim
TIMXJ is offline
post #2 of 11 Old 10-24-2011, 03:18 PM
94chb
saggy springs?
94chb is offline
post #3 of 11 Old 10-24-2011, 03:20 PM
steelman10
Yes they are farther forward than mine. I'm looking out the window at mine right now and they are centered. I don't know for sure but I heard there was a long end and a short end on the springs maybe the p.o. put them on backwards?
steelman10 is offline
post #4 of 11 Old 10-24-2011, 03:23 PM
jbolty
jbolty's Avatar
Looks pretty normal. Generally the wheels move back as the springs compress since the front is anchored and the shackle moves outward.
jbolty is offline
post #5 of 11 Old 10-24-2011, 04:09 PM
W_A_Watson_II
How does the body line up with the rear of the frame? Does the body extend further rearward than the frame?
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline
post #6 of 11 Old 10-24-2011, 04:47 PM
PA_YJ19
just looks like ur spring are sagging bag, almost inverted...so its going to look tucked toward the front of the fender well. I'd look into replacing those springs, they cant ride too smooth like that.
PA_YJ19 is offline
post #7 of 11 Old 10-24-2011, 05:21 PM
hesserdude07
looks right from here
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #8 of 11 Old 10-24-2011, 06:37 PM Thread Starter
TIMXJ
Body lines up good....
Spings are flat, almost inverted. I guess that is the problem then.
TIMXJ is offline
post #9 of 11 Old 10-24-2011, 08:18 PM
Castr8r
If it's just one side, you may have a broken/sheared spring bolt.
I've been throwed out of a carwash- too much mud!
I've done bodywork useing a winch, a tree, a prybar, and a BFH!
Now, my wild oats have turned to prune juice and all-bran...
Castr8r is offline
post #10 of 11 Old 10-24-2011, 08:21 PM
Kraxen
that is one clean/nice YJ man.
92 YJ
95 YJ
Kraxen is offline
post #11 of 11 Old 10-24-2011, 08:24 PM
Old4X
1990 CJ7
The position of the axle can be adjusted with spring plates with several pin locating holes.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
Wrong side axle shaft=axle off centre?? 2000GrayTJ TJ Wrangler Technical Forum 1 10-18-2011 04:35 PM
Steering connected wrong after axle swap scottieboy YJ Wrangler Technical Forum 5 04-04-2009 03:24 PM
Wrong ARB and new axle shafts installed bonofied suiter TJ Wrangler Technical Forum 20 09-28-2008 11:12 PM
Buying new rear axle w/wrong gears Cash TJ Wrangler Technical Forum 30 11-21-2007 06:16 AM
Replaced rear axle seal, did i do something wrong? TomC TJ Wrangler Technical Forum 7 09-21-2004 06:18 PM
