What would you do ????? Pic Heavy - Page 2 - JeepForum.com
post #16 of 27 Old 02-15-2013, 09:31 PM
giggityjeeper
IF you decide to fix it which if you cant weld is NOT an option, you CANNNNNOT 'rivit' a frame together bodypanels meh.....
anyhow check out my thread in mysig... the rust repair one.... see kinda what you in for if you decide to fix it which if you have a frame and body I would not I would swap it
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #17 of 27 Old 02-15-2013, 11:34 PM
rodgers3
How hard would it be to repair a hole in the frame where the shock mount is on the passenger side is?
Im learning how to weld in metals and have a welder. Its the same hole as the pic above but the shock mount is intact.
rodgers3 is offline
post #18 of 27 Old 02-16-2013, 12:38 AM
Shadownwpa
Dang, and I thought my $1100 heep had alot of holes. At least yours looks better from a distance. I think you should pull the flares and rollbar and start picking the scabs to see how bad it really is, then get a little mig and learn how to use it on the tub repairs... after that use your own judgement on whether you have the skills for the frame repairs.... unless you can get your money back and get a jeep less labor intensive.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #19 of 27 Old 02-16-2013, 05:17 AM
NHfireLJ
NHfireLJ's Avatar
Thats and easy repair, and probably a good spot for a new welder to try, Practice on scrap first. Cut out the bad to get clean metal and fill it with a new piece... If the shock mount is on solid steel then leave it..If its rotted under the mount then cut the whole mount out and start fresh...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #20 of 27 Old 02-16-2013, 05:57 AM
giggityjeeper
go thru my thread........ the rust u have i had and fixed. same frame spots same seatbelt spot the top is easy, is the rest and add it all up its a big job..
what shadow said, its like an iceberg u only sell 20% of it the rest is hiding start tearing it down see how bad it really is
post #21 of 27 Old 02-16-2013, 11:15 AM Thread Starter
Gage56
OK So here is the deal
the guy has a Perfect TJ Tub & Frame With Axles i can get all of it for 700.00
Now the question is ....................
Can i use the YJ Dash and motor/ trans/ transfer case in and on the TJ Stuff ????????
Gage56 is offline
post #22 of 27 Old 02-16-2013, 11:21 AM
modfox
You could
But
It's not a direct bolt in. I believe there is some modification needed.
You will need the TJ doors and top also.
90 YJ 4 cyl 5 speed
65 Ford Mustang 289/c4
2010 Kia Soul
modfox is offline
post #23 of 27 Old 02-16-2013, 11:22 AM
modfox
The motor and trans will fit fine.
90 YJ 4 cyl 5 speed
2010 Kia Soul
modfox is offline
post #24 of 27 Old 02-16-2013, 11:22 AM
insaneinline
I just got done repairing my tub and it needed quite a bit of work if I did it over I would just replace the tub if you take it apart you will probably find more rust than you think you have now
insaneinline is offline
post #25 of 27 Old 02-16-2013, 11:40 AM
rodgers3
Iv went over the whole frame with a screw driver and that was the only place it punced through.
So i need to repair that and the rust in my floor pan.
rodgers3 is offline
post #26 of 27 Old 02-16-2013, 11:54 AM
pasinbuy
I also had no welding skills at one time.
What I did was to pick up a gas mig welder for welding thin body steel. Then went to a salvage yard told them I wanted a scrap car door to practice welding on. They gave me a door no charge.
Spent a little time practicing and started my project. I am still not a good welder but I am good enough to get by and can fix things as I go due to now owning a mig welder. I also picked up a arc welder for $100.00 and oxygen acetylene gas torch for cutting and heating.
I went to a welding shop picked up some scrap metal to learn how to arc weld. Oh yea, I also read the instructions that came with the welder.
From the pics you posted spend the $700.00 on the welder and equipment. You will be far ahead.
pasinbuy is offline
post #27 of 27 Old 02-18-2013, 10:10 AM Thread Starter
Gage56
Ok so i got to check over the fame better the other day and its not as bad as i thought SO ill be picking up the new tub this sat but prob will not get to put it on till spring . For now im just patching the holes in the old tub just enough to get it inspected and i rebolted the seatbelt to the roll bar for now
Gage56 is offline
