What would be the proper way to terminate a wire end? - JeepForum.com
post #1 of 7 Old 02-26-2010, 02:29 PM Thread Starter
kidddhawk
I'm running a mc2100 and nuttered 258, and upon cleaning up some of the uneeded stuff in the engine, and getting rid of some other junk the PO had in there, I'm left with some wires in the wiring harness that come out of the loom above the valve cover area. Taking the loom and harness the whole way apart to take the wire out the whole way seems a bit much at this point, but I'd like to cap them off some reliable and safe way that isn't going to start a fire down the road. Should I solder some caps on there and do some heat shrink around them or something like that? Wiring is not really my strong suit so any advice is appreciated...
kidddhawk is offline
post #2 of 7 Old 02-26-2010, 02:38 PM
raynmaker
can be done several ways. easiest is to use heat shrink and pinch the end with your fingers. only burns for a second! lol Other way is to get some of the terminals the phone company uses with the grease in them.
Dont use elect tape it traps water and do cover the end. if the wire starts to corrode it will spread to other wires. Seen that on salt water boats. eeeewww!
raynmaker is offline
post #3 of 7 Old 02-26-2010, 02:38 PM
jbolty
jbolty's Avatar
heat shrink over the ends then wrap some tape around the whole thing.
jbolty is offline
post #4 of 7 Old 02-26-2010, 06:04 PM
Brown Dog
Vendor
Brown Dog's Avatar
Or...a crimp style terminator.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #5 of 7 Old 02-26-2010, 08:24 PM
TSEJEEPERS
Put some heat shrink on the end with some hanging off. Heat it, bend it off and put another peice of heat shrink over it and heat it again.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 7 Old 02-26-2010, 08:41 PM
TSEJEEPERS
Just a thought and I am not sure if you can find it anymore but, what if you used some Plasti Dip and just dipped the end of the wire in the Plasti Dip.
I guess it is still around. Not sure if you can find it locally.
Performix / Plasti Dip from ToolSavings, LLC
post #7 of 7 Old 02-26-2010, 09:00 PM
H_Swank
I took a small piece of electrical tape put it over the top of the wire and wrapped it around the top, then heat shrink it, then repeated if it was a + wire. That process has always worked for me
1991 YJ, Powered by a 97 TJ 4.0L AX-15 tranny, NP231 xfer
2005 WK, ALL Stock
"Never trade the thrills of living, for the security of existence" Live and love as if its your last day!!
Life is no fun unless, you take the path with the most resistance. -ME-
H_Swank is offline
2 wire LEDs to 3 wire conversion (write up) zachjf TJ Wrangler Technical Forum 149 04-17-2017 11:57 AM
Anyone ever mastered the 3 wire turn signal rewired to the 2 wire LED Rippers TJ Wrangler Technical Forum 28 06-08-2016 01:29 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
95 YJ--Which wire is the crank(start)wire?? jnkyrdg04 YJ Wrangler Technical Forum 0 03-09-2007 01:27 PM
