What would cause breaks to set on fire? - JeepForum.com
post #1 of 8 Old 05-13-2002, 02:43 PM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
The front pass side brakes caught fire. Should I just replace the caliper? How hard is it to do? Also, my rear driver side brake is leaking brake fluid, what would the cause and solution be for that?
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 8 Old 05-13-2002, 03:39 PM
Plink
Plink's Avatar
Sounds like the caplier has seized. It's an easy job to replace it and I believe refurb. cost around $20.
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #3 of 8 Old 05-13-2002, 03:42 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Sometimes it works better than others. Still think its the caliper? And any idea about the rear drum?
Currently: '14 JKU
post #4 of 8 Old 05-13-2002, 03:54 PM
JeepinNH
My wife's seized up also. Smoked but did not catch fire. The next year her rear cylinders also started leaking, then mine.
It's time for a complete brake job front and rear.
Is this going to be a new experience for you? <img border="0" title="" alt="[Eek!]" src="eek.gif" />
91 Wranger, 3" body lift, 33" tires
everything else - stock
thinking about RC lift
Wife's has 91 Wrangler, Shackle Lift running BFG 31" "Yellow"
JeepinNH is offline
post #5 of 8 Old 05-13-2002, 05:03 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Yup, I just bought a caliper. I'll fix the front one first. THats the major problem right now. But I need to know more about the rear first.
Currently: '14 JKU
post #6 of 8 Old 05-14-2002, 03:36 AM
JeepinNH
I hope you bought both sides and new pads. If one goes the second is not to far behind.
On the rear it is the part called the "wheel cylinder". It is connected directly to the break lines and pushes out two pistons on each end to apply pressure to the shoes. Once they start to leak they are shot. The only problem you may have replacing them is removing the brake line. A little heat should help. Get new shoes and a spring kit also. Some "Brake Klean" spray will remove all the fluid and gunk.
JeepinNH is offline
post #7 of 8 Old 05-14-2002, 01:38 PM
4wheeler4CJ
4wheeler4CJ's Avatar
See my reply to your other post. Go thru and do COMPLETE brakes, front and rear. Seriously, go all-out, you won't regret it.
4wheeler4CJ is offline
post #8 of 8 Old 06-06-2002, 08:55 AM
lostboy
Sounds like the seals have gone on them.What can cause this is using other than the recommended fluid or an incompatible fluid.Melts seals in quick order. Just completed a brake job on such a car...owner used non-recommended fluid....She has WHOLE NEW brake system now.....It was a foreign car though ...haven't heard of this in a jeep ... but it CAN Happen
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
New breaks Corey4x4man TJ Wrangler Technical Forum 1 01-03-2007 09:49 PM
doing my breaks bobbert350 YJ Wrangler Technical Forum 10 10-03-2006 11:29 PM
breaks breaks and E-brakes YJXtreme YJ Wrangler Technical Forum 8 11-30-2003 09:50 AM
breaks again? my_tj TJ Wrangler Technical Forum 4 10-01-2003 01:24 PM
fire fire! pics *Jeremy* YJ Wrangler Technical Forum 13 09-25-2003 10:35 PM
