What would a 4L I-6 cost and whats the intall like?
#1 | |
Well what would it cost for a YJ (95)?
I am looking at a VERY nice 2.5 tomorrow and want to know how tough the engine swap is.
#2 |
Why swap it? Ask anyone here, the I4 has more than enough for ya (unless you plan on putting 37's on it). I thought my I4 would struggle, hehe how wrong was I. The low low gears tear up off road, its performed much MUCH better than I expected. All the I6 will get you is more speed on the interstate. For the cost of buying and I4 and then an I6 (including its tranny and most likely the t-case) and THEN installing it, hell, I would just go find an I6 out there, ALOT cheaper and ALOT easier. But don't rule out the 4 just yet, there's tons of power mods out there too. Cheap cheap ways of tuning it out.
#3 |
as canuk stated, to do the swap you will need not only the 4.0 motor, but also the PCM and wiring harness, the AX-15 transmission and you will hafta rebuild the NP231 xfer case to have the proper spline counts. if you are just looking for a YJ now and you seriously want the 6; then get the 6.
g'luck |
#4 |
Pimp Hand
you might just as well swap in a ford 302 or chevy 350.. it will be about the same meoney ehen you are finished
![]() or just buy a jeep with the 4.0 in it already
___________________________________________ What is all of this talk of Savvily designed products?
#5 |
Well it is a SWEET Jeep so I think I will have to suffice with the 4 banger. It does come with a Magnaflow that is probably good for a pony or two.
The RE 4 1/2 kit and SYE and other goodies are the selling points Im interested in. This thing is pretty dang cool. |
#6 |
Pimp Hand
if it doesnt have tall gears in it already, put that on your list of things to do. stock is 4.10 for the 4 banger... for 33-35" tires, i'd go to 4.88 gears. that will keep you in good power range. the 4 bangers wheel great!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
