what will repair a plastic fuel tank - JeepForum.com
post #1 of 40 Old 08-02-2009, 12:04 PM Thread Starter
payprviews
I have a small hairline crack on my plastic gas tank. It is about an inch long. Very thin I can't even see it unless it's leaking. I wipe it clean and I can see it is very thin hairline crack.
What can repair this. I tried the Autozone stuff. Expoxy stick for plastic tanks and that stuff is just to weak even when dry you can just peel it off.
Will mighty putty work. I know I need to really get a new tank but that is not possible today anyway
Or will the plastic welder work better? I have read some here but what works best? Other than a new tank.
payprviews is offline
post #2 of 40 Old 08-02-2009, 12:15 PM
Reverb
I used JB Weld. It's held up for the last 4 months no problem. I went overboard with it though - covered about 4 inches more than I should have around the leak.
Reverb is offline
post #3 of 40 Old 08-02-2009, 12:19 PM
lwszabo
is it a stock tank? I have a 95 and thought mine was metal.
lwszabo is offline
post #4 of 40 Old 08-02-2009, 12:20 PM Thread Starter
payprviews
Jb weld, i thought of that. Is yours a plastic tank? what did you clean the outside of your tank with? I think part of the reason my patch did not hold was cause it was satuated with gas for some time. I pumped out as much fuel as would come out without removing the tank already. what should i clean the area that leaks with?
post #5 of 40 Old 08-02-2009, 12:23 PM Thread Starter
payprviews
I dunno if it's stock. but it's heavy black plastic. I took off the skid plate and am ready to work on it again. the original patch did not hold yesterday. i used the plastic tank repair kit from autozone. the expoxy was kinda dry and brittle. it didn't mix well there was lots of small hard pieces in it. starting to wonder if it has a shelf life that was expired. what a waste of 12 bucks.
post #6 of 40 Old 08-02-2009, 12:24 PM
Reverb
Yeah its a plastic tank. Mine was almost empty when I patched it. I cleaned the area with carb cleaner I think, just make sure all the gas has evaporated. Its much easier to do if you drop the tank - you can position the crack so nothing leaks from it. A new tank wasn't an option at the time because they are about $400.
Reverb is offline
post #7 of 40 Old 08-02-2009, 12:36 PM
jay-h
There is no adhesive for the polyethethylene plastic tank. Basically no adheseive really works because it will not chemcially bond. You will note that adhesivse are not used in the factory on PE parts for that reason.
jay-h is offline
post #8 of 40 Old 08-02-2009, 12:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Dead on.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 40 Old 08-02-2009, 12:50 PM
pasinbuy
For a temporary repair try Empty tank so crack is not leaking, cleaning the area very good with carb or brake cleaner. scratch a v groove on the crack, take some sand paper to the area. then try JB stick weld for plastic. If that does not do the job, nothing can.
pasinbuy is offline
post #10 of 40 Old 08-02-2009, 12:55 PM Thread Starter
payprviews
Originally Posted by Mean Max View Post
Dead on.
Max
Ok, thanks..what about the plastic welder idea?
Where we're going....we don't need roads.
post #11 of 40 Old 08-02-2009, 01:12 PM
jay-h
Plastic welding in the factory is done electronically essentially focused microwaves are channeled through the tooling. It is very hard to weld that stuff with hot tools because it conducts heat so poorly that the surfac melts wthout thoroughly heating the material.
jay-h is offline
post #12 of 40 Old 08-02-2009, 01:18 PM
Mud-n-Beer
I'm not too sure if this would work on plastic, but I'm pretty darn sure it would. I have sealed a very badly rusted metal gas tank with a product called Seal-All. This stuff is made for gas & oil leaks. I used it for a badly rusted fuel tank in a long gone 84' S-10 pickup. The tank was so bad, I could put my fingers through it. I was just going to put it on, till I could get another tank, but this stuff worked so great, and I never had to buy the tank.
I first drained the gas tank, then I drove it up on car ramps. Had to wait a little bit for the last bit of gas to drain out. Let it sit overnite to make sure the tank was dry. Put on a good bit of the Seal -All, and covered the Seal- All with some thin rubber. I held it up in place with some pressure, since my leak was on the bottom. Drove it for many, many years, and it never leaked.
I always make sure I have a tube on hand, just in case I need it. Its also great for many other kinds of leaks. It comes in a yellow & red tube, 2fl.oz. Wal-mart sells it, among other places. This stuff works great, just prep the surface as best as you can.
Mud-n-Beer is offline
post #13 of 40 Old 08-02-2009, 01:22 PM
stu1021
Here is a supplier for new 20 gallon tanks for $285 - free shipping.
http://cgi.ebay.com/ebaymotors/1987-...Q5fAccessories
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #14 of 40 Old 08-02-2009, 01:50 PM
pasinbuy
Good to know, but he has aplastic tank.
I still say try the JB plastic weld. What do you have to loose. If it doesn't work then go buy a new tank.
pasinbuy is offline
post #15 of 40 Old 08-02-2009, 01:56 PM Thread Starter
payprviews
ok i am gonna try something. even it its one thing after the other. i'll let you know if anything works. thanks for all the suggestions.
20 gal plastic fuel tank sending unit Reverb YJ Wrangler Technical Forum 5 10-25-2009 03:39 PM
Fuel Tank Skid Plate plastic or metal PhilipSandgren YJ Wrangler Technical Forum 3 02-14-2009 06:01 PM
TJ plastic dash repair?? crashdnt TJ Wrangler Technical Forum 11 02-06-2009 10:39 PM
YJ 20 Gallon Plastic Fuel Tank fran87yj YJ Wrangler Technical Forum 14 05-04-2008 07:38 AM
Repairing hole in plastic fuel tank.. Swampwalker3 YJ Wrangler Technical Forum 9 04-02-2007 09:40 AM
