What width rim and backspacing do I need? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What width rim and backspacing do I need?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 09-22-2008, 12:08 PM   #1
jtoddellis
I have 33x12.5x15 goodyear wrangler silent armor tires on my 1989 yj. If i turn very hard the tires rub my front springs. The whees on it are aftermarket and make the tires stick outside the fender flares, but i do not know the backspacing on them. I would like to order some wheels to correct my rubbing prblem, but dont want to order the wrong ones. If it makes any difference the jeep has 2" lift springs on it and a 3" body lift.
Thanks for your help
jtoddellis is offline   Reply With Quote
Unread 09-22-2008, 12:15 PM   #2
Brandon_YJ
1987 YJ Wrangler
Have you considered wheel spacers?
Your rim width is usually determined by the tire you chose, and since you already have aftermarket wheels (assuming you like them) wheel spacers are an option.
Personally I don't like them, but there are some automotive manufactures that include them OEM on their cars.. you'll hear pros and cons of them... enough rambling.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Unread 09-22-2008, 12:19 PM   #3
jtoddellis
I've considered spacers, but scince I drive it every day, i think i'd feel safer replacing the rims.
Unread 09-22-2008, 01:37 PM   #4
ghost183
what size rim width is currently on there?
when i had 33' on an 8 inch rim i had the same issues, so i turned the steering stops out until i bought a set of 10 inch rims which threw my tires waaaay out there, i had to get 7" flares to compensate, but now, im running 35' on a 10 inch rim with NO rubbing, and oh, i left the steering stops where they were to prevent overturning the u joints
usually an 8" rim has between 2 1/2" - 3 inches of backspace, but a 10 inch rim has 3 3/4" to 4"
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline   Reply With Quote
Unread 09-22-2008, 01:45 PM   #5
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
more backspacing bring the tires in, not out. less pushes the tires out farther.
Poke is offline   Reply With Quote
Unread 09-22-2008, 02:36 PM   #6
ghost183
thats correct,
i.e....
8 inch rim with 3" backspacing, you have 5 inches stickin out past the mounting surface
but on a 10 inch rim, with 3 3/4 inch backspacing, you have roughly 6 1/4 inches sticking out past the mounting surface
now considering stock rims had a disgusting 5" in and 2" out (roughly), to stay under the flare.. you can see how far out a 10 rim would throw the tire
sorry if my previous post was confusing
