WHAT is this white goo in my valve cover. - JeepForum.com
post #1 of 5 Old 11-18-2013, 08:20 PM Thread Starter
Jeepsterdoug
2010 JK Wrangler
WHAT is this WHITE GOO, in my valve cover????? I have a 89' Wrangler w/4.2, and I noticed in my oil filler cap there is this whitish, tannish Goo. I haven't taken the valve cover off yet. It appears to be hanging in the top inside of the valve cover, there is none of this guk in my oil pan or radiator. It sorta looks like dirty crisco.the motor was rebuilt about 2,000 miles ago or fewer. The oil has been changed. I have never seen anything quite like this. I can not tear into it till the weekend. I have noticed I have brownish dirty spot that it blows onto the driveway on startup. This has not seemed to do this once it is started but, I really have not looked once I park & turn it off. It is sorta rusty looking brown. My gas mileage has sucked, well .... You know worse than it should. This jeep pretty much has been gone over & yet when I think I'm good, something else happens.... Yeah, right It's aJeep Thing. If anyone can give me any advice or tell me how to fix it, or where to look to figure out what this is??? All help is greatly appreciated. I am including a couple pictures if it.
Jeepsterdoug is offline
post #2 of 5 Old 11-18-2013, 08:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Water.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 5 Old 11-18-2013, 08:29 PM
bpounds
bpounds's Avatar
Yeah, water or coolant. Never a good thing. Most often it means a head gasket has blown. But I have owned a truck that would do that from condensation and it would burn off after a long run. If you're lucky it is left over coolant after the rebuild. I hope so, but I doubt it.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #4 of 5 Old 11-18-2013, 08:33 PM
rykemc
Same thing on mine after I rebuilt my 4.0. Pulled valve cover off and double checked everything. Cleaned it up and changed the oil. No problems at all after that. Could be some condensation build up that mixed with the oil or prelube from the build.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #5 of 5 Old 11-18-2013, 09:39 PM
Chrisnvegas
Chrisnvegas's Avatar
Perhaps you have a case of short-trip-itis. It's a common malady cause by excessive short trips to the liquor store without reaching proper operating temperature resulting in a buildup of condensation in the oil and exhaust.
My recommendations? take that beeoch out on the highway once on a while and heat her up. Anything less than 5 to 7 miles is considered a short trip. Especially in cold humid climates.
Or, you have a bad head gasket.
Ban computer updates, auto-play video and music without real instruments.
Chrisnvegas is offline
issues , problems , technical
