What is this wart on my front axle? - JeepForum.com
post #1 of 3 Old 06-24-2002, 12:37 AM Thread Starter
moabster
moabster's Avatar
2011 WK
When I pulled the front passenger tire while installing a lift kit I discovered a wart on the passenger side of the front axle. After looking in my chilton's manual I discover this is a "shift motor" and a 4x4 sensor. The shift motor has a couple of vacuum lines going to it and the 4x4 sensor has a couple of wires that controls the 4 wheel drive light (mine is always on ). The shift motor is suppose to couple the front axle when in four wheel drive. Now I'm confused
Doesn't the transfer case disable power to the front wheels when not in 4 wheel drive?
Isn't there a differential in the front axle that allows the wheels to turn at different speeds when cornering?
If so, then why is the axle on the passenger side split with a mechanical coupler used to connect it? It seems this is redundant?
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #2 of 3 Old 06-24-2002, 07:23 AM
RodeoRob
RodeoRob's Avatar
That is indeed your vacuum shift motor. And it does couple the front axle when in 4wd. The deal is, instead of using hub lockouts, Jeep decided to go with hubs that are locked all the time and instead disconnect the passenger side axle shaft. So, your inner passenger shaft is actually two pieces, and what the vacuum motor does is slide a lockring to engage the two parts of the inner shaft.
You're right, the tcase does disengage power to the front axle. but because of the "always locked" hubs Jeep uses, if you didn't have the vacuum disconnect, your front driveshaft would spin all the time, even in 2wd.
FYI, the vacuum motor is often a cause for failure of 4wd on YJs. Some poeple replace it with a cable actuated motor, or defeat it all together by switching to 1-piece TJ inner shafts.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 3 Old 06-24-2002, 10:22 AM
Jeepfreak81
Jeepfreak81's Avatar
from what ive seen that front shaft spins all the time anyway but i think its just the drag.... if your 4wd light is always on it is most likely the sensor on top of the t-case... it has 4 vacuum lines on it, is about an inch in diameter and is a pain to replace if you have to lie under the jeep because of its position... they are around 14 bux to replace... thats what was wrong when my light wouldnt shut off... if you ever have to replace that actuator motor thats about 110 bux... i have done that too..
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? MWguy101 YJ Wrangler Technical Forum 21 03-01-2012 11:08 AM
front outer axle seals and axle shaft runout... mudb8 TJ Wrangler Technical Forum 32 01-02-2011 12:49 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 02:00 PM
