What is the voltage going to the fuel gauge float? - JeepForum.com
post #1 of 6 Old 08-11-2014, 09:13 AM Thread Starter
YJames90
YJames90's Avatar
I have a fuel cell in the back of the Jeep that didnt come with a gas guage float.
I took apart the YJ sending unit and removed the float unit and will be installing it in the cell.
What is the correct voltage in the wire going to the float?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #2 of 6 Old 08-11-2014, 09:53 AM
Mike Romain
It is a variable resistor to ground. The gauge reads the resistance to give the reading.
Mike
Mike Romain is offline
post #3 of 6 Old 08-11-2014, 10:20 AM
tom_sprecher
Not quite. The gauge measures the current flowing through the variable resistor to ground. The voltage at the variable resistor changes with current. Google how a fuel gauge works for several diagrams, explanations and even videos.
Tom
tom_sprecher is offline
post #4 of 6 Old 08-11-2014, 10:39 AM Thread Starter
YJames90
YJames90's Avatar
Its a hot wire. I was getting 8 volts not hooked up to anything and it does work correctly when wired up
YJames90 is offline
post #5 of 6 Old 08-12-2014, 09:32 AM
Que89YJ
You have 12 volts on the cluster. It goes through the gauge to a wire that connects it to the variable resistor the float operates to ground. 8 volts is about right with the voltage drop on the gauge and wire.
Que89YJ is offline
post #6 of 6 Old 08-12-2014, 11:31 AM
bpounds
bpounds's Avatar
7.5 volts per the FSM.
Sender values are:
Empty = 0 ohms
1/2 tank = 44 ohms
Full = 88 ohms
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
