What to use for a center pin in a spring pack? - JeepForum.com
post #1 of 19 Old 12-06-2009, 12:29 PM Thread Starter
dodger889
Trying to figure out what to use for spring pack center pin.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #2 of 19 Old 12-06-2009, 12:32 PM
timatoe
timatoe's Avatar
I've heard of guys just using a bolt and rounding off the head, but why not just order some new pins??
Replacement Center Pin - Builder Parts - Jeep - Rubicon Express
https://catalog.foothilloffroad.com/...3e65f53f4e1c11
Explorer Pro Comp Leaf Spring Centering Pin
timatoe is offline
post #3 of 19 Old 12-06-2009, 01:10 PM
bpr
O'Reilly autoparts got me a pair in one day about 2 bucks I think.
bpr is offline
post #4 of 19 Old 12-06-2009, 01:19 PM
Super D
I second just getting new proper pins.
Super D is offline
post #5 of 19 Old 12-06-2009, 01:26 PM
jeepercreeper77
jeepercreeper77's Avatar
I ordered some from the local auto parts srore. dorman/motormite makes them. just had to cut them down alittle.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #6 of 19 Old 12-06-2009, 02:30 PM
yj93ben
Centering pins
Easiest; Go to NAPA. They usually have them in stock. You just need to know the diamiter 5/16 or 3/8. They are all cut to length. Buy a coulpe of extras, they come in handy. Also if you find yourself on the trail needing one, a 1/4" drive extesion about 2" long works great. Voice of experience, I sheered one off on the trail once and this kept me wheelin' for the weekend. Now I just carry a couple extras.
yj93ben is offline
post #7 of 19 Old 12-06-2009, 02:44 PM
wildchild
Order 3/8 pins and get a good drill bit. Drill the springs out to 3/8 and the pins will not break as they do using the 5/16 center pins I've done this on all my jeeps. If you have a lift and are using wedges for your pinion angle the small pins will break quite often. After I drilled my first set I never had one break again. But make sure you buy some quality center bolts not the ones the chain stores sell.
wildchild is offline
post #8 of 19 Old 12-06-2009, 03:42 PM
93jeepyj
Ive used bolts with a allen socket cap on them in a pinch and they actually worked out pretty well.
93jeepyj is offline
post #9 of 19 Old 12-06-2009, 05:11 PM
TSEJEEPERS
Yep have never had a problem with using allen head bolts.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #10 of 19 Old 12-06-2009, 07:38 PM
Dreygo
Just use a grade 8 bolt, lock washer, and nut.
USAF Pavement and Equipment Operator AKA: Dirtboyz Air Force Jeep Club Member 51
1995 YJ 4.0 I-6, AX-15, NP231 w/JB Super Short, Dana 30/35, 4.10 gears. 4" lift, 33X12.5XR15 Goodyear Duratracs/Cragar V Series, Homemade front bumper w/Hella 700FF
Dreygo is offline
post #11 of 19 Old 12-06-2009, 08:01 PM
chadroc
X3- I've heard of that many times
chadroc is offline
post #12 of 19 Old 12-06-2009, 10:39 PM
fratis
fratis's Avatar
if you are going to follow the advice of drilling out your spring pack be prepared to spend time doing it. i only had to widen holes in 2 leaves and it took forever. wound up using a round file.
fratis is offline
post #13 of 19 Old 07-17-2010, 12:02 AM
ValleyJeeper
Since the subject is the center pin for leaf spring pack, how tight do you tighten them?
I ask because I just got a pair of replacement springs and the center pins were installed upside down and I had to reverse them.
ValleyJeeper is offline
post #14 of 19 Old 07-17-2010, 12:15 AM
cubewhiz
I get spring center pins, bolts, nuts, washers, etc. from a local spring place.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #15 of 19 Old 07-17-2010, 04:09 AM
dadstoy
get spares when you do buy them. I keep a set in my trail bag for those "just in case" times.
dadstoy is offline
Leaf pack center pin Fun2Jeep YJ Wrangler Technical Forum 8 09-22-2009 08:42 PM
Replacement spring pack reccomendations Fun2Jeep YJ Wrangler Technical Forum 14 02-06-2009 11:28 PM
need some spring pack advise will_982 YJ Wrangler Technical Forum 2 01-04-2009 02:49 PM
bolt that runs thru front spring pack broke ton12loc YJ Wrangler Technical Forum 4 10-08-2008 12:38 PM
best soa mixed spring pack shark3471 YJ Wrangler Technical Forum 10 09-05-2006 12:29 PM
