What Type of Oil Do You Run In Your 4.0L? - Page 2 - JeepForum.com
 1Likes
post #16 of 27 Old 07-01-2011, 08:38 PM
sitedzn
Cam2 10w30 w/ 1 quart HD Lucas oil treatment and my $1.99 filter. Entire change costs $15. Oh ya, forgot to mention I work at the parts store & get for cost. Also, our filters have twice the pleats as a regular Fram. W/o the Lucas, costs like $12.
The Lucas was for the first time - heard good things so thought I'd give it a whirl.
88 YJ, 4.2L, AX-15, NP231 w/ SYE, 3.5" RC lift, 1" booms
Cut down XJ shaft in rear
Ford 8.8 LS & Spartan Locked
D30
Big Daddy Off Road rock sliders
35x12.5 BFG A/T KOs, XRC-8000
I love installing new stuff.
sitedzn is offline
post #17 of 27 Old 07-01-2011, 09:13 PM
bec
Mobil 15w40
bec is offline
post #18 of 27 Old 07-01-2011, 10:04 PM
DW8520
Redline 10W30
DW8520 is offline
post #19 of 27 Old 07-02-2011, 06:56 AM
YJay92
My engine used to tick like crazy, switched to royal purple 10w30 to try it out. No more tick.
1992 YJ, 4.0, auto, HP D30 w/TJ chromolys, 8.8 LSD, 4.10s, AA SYE, Tom Woods shaft, 5" lift, 35" MTZ's, 12k winch, Mark VIII fan, 136 amp alternator, TJ flares, custom snorkel and rock rails, no track bars or sway bar
YJay92 is offline
post #20 of 27 Old 07-02-2011, 07:58 AM
jay-h
Mobil 1 10-30 high mileage for the past 80K miles (now at 220K)
[Unless you are dealing with a specific wear problem or doing something temporary like using Seafoam just before oil change to clean things out, buy good oil but don't put in additives (this is the general recommendation of automotive engineers). Good oils come with a balance of additives (yes, they interact) and throwing something else in can actually degrade performance.]
jay-h is offline
post #21 of 27 Old 09-10-2017, 11:58 AM
Jeep25
Bringing up an old thread.
If you have no idea of past oil's used what oil should I use for a low mileage (40k) 2003 4.0 5 speed?
Jeep25 is offline
post #22 of 27 Old 09-10-2017, 01:20 PM
bpounds
bpounds's Avatar
Does not matter what is in it now. You can mix any motor oils, and no harm will be done. Not like the earliest attempts at synthetics. Everything is compatible these days.
High mileage oils just have leak preventatives in them Nothing special other than that. I would fix leaks instead of using those, but to each their own.
Congrats on finding a 40k YJ to call your own. Except it's not a YJ, and you're in the wrong forum. Still a 4.0 though, so same advice applies.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #23 of 27 Old 09-11-2017, 07:05 AM
Chrisnvegas
Chrisnvegas's Avatar
Avoid running snake oil.
Any decent 10w30 will be fine.
Use conventional Lucas gear oil in the diffs not synthetic per ECGS.
They say the dino sticks to gears better and provides a bit of cushion between parts. They say synthetic thins out and drips off parts faster.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #24 of 27 Old 09-11-2017, 02:55 PM
rocketboy
rocketboy's Avatar
Mia: They talk a lot, don't they?
Vincent: They certainly do.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is offline
post #25 of 27 Old 09-11-2017, 08:47 PM
Chrisnvegas
They say the worst is Royal Purple.
I read the article right after I filled my diffs with... Royal Purple.
They are swearing by Lucas.
I don't know.
Henry Ford
post #26 of 27 Old 09-11-2017, 09:54 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
rocketboy likes this.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #27 of 27 Old 09-11-2017, 10:17 PM
2oldjeeps
on "advice" i use shell rotella t4 reg 15w 40. notice no difference from 10/30 on pressure, 40-50 lbs .
still have piston slap..
2oldjeeps is offline
gas type orengutan YJ Wrangler Technical Forum 9 06-16-2011 09:38 AM
What type of SYE is it? jeep973 TJ Wrangler Technical Forum 5 02-26-2011 09:11 PM
98 Tj ATF type? myriad360 TJ Wrangler Technical Forum 3 07-27-2009 09:23 AM
Type of Oil BaystateTJ97 TJ Wrangler Technical Forum 5 02-10-2008 11:57 AM
whats better "spacer" type t-case drop or the bar type ? 87wranglersport YJ Wrangler Technical Forum 4 10-05-2007 07:02 AM
