what tranny/transfer fluid to use 4.0 - JeepForum.com
post #1 of 4 Old 06-22-2010, 06:18 PM Thread Starter
eas0202233
I just bought a 93 jeep with the 4.0 and 5 speed. I guess it has the apx15 in it. i want to change my fluid in both and not sure what to buy. I heard 10w30 10w40 for tranny and gear oil. And not sure about the transfer case. Is synthetic better than standard? Is deisel oil better than gas oil.
eas0202233 is offline
post #2 of 4 Old 06-22-2010, 06:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/b...change-865490/
http://www.jeepforum.com/forum/f12/b...change-865520/
http://www.jeepforum.com/forum/f12/b...hange-1009078/
http://www.jeepforum.com/forum/f12/b...enance-728231/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 4 Old 06-22-2010, 06:32 PM Thread Starter
eas0202233
now i have 2 questions what ATF to use?? And is synthetic 10w30 better than none?
post #4 of 4 Old 06-22-2010, 06:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It depends on your conditions & preference in my opinion.
Here in swampy South Florida, water intrusion is a fact of life & happens with almost every outing. Subsequently the fluids are changed often due to the water & not because of their service life.
In drier conditions where water isn't a consideration, higher quality fluids may be preferred.
Max
Mean Max is offline
Transfer / Tranny Fluid, What do you use and why? kittyhawk TJ Wrangler Technical Forum 5 12-18-2007 06:04 PM
What fluid in the tranny and transfer case? funJ YJ Wrangler Technical Forum 2 06-28-2007 06:55 AM
tranny and transfer case fluid timeteo YJ Wrangler Technical Forum 4 02-18-2005 01:21 PM
'04: Manual Tranny/ Transfer Case Fluid (+4?) mkuzmukerau TJ Wrangler Technical Forum 7 02-11-2005 09:22 PM
Transmission Fluid, Diff Fluid, and Transfer Case markdonnell1975 TJ Wrangler Technical Forum 3 05-27-2004 02:27 PM
