What tools for drum brake job? - JeepForum.com
post #1 of 17 Old 02-17-2012, 11:23 AM Thread Starter
terryjeep
Will be attempting rear brake job this weekend. Have replacement part kit from Quadratec, but need to know what brake specific hand tools I am going to want. No intention of replacing the drums or cylinders, just shoes and hardware. As always, thank you for your time and interest.
terryjeep is offline
post #2 of 17 Old 02-17-2012, 11:28 AM
jbolty
jbolty's Avatar
Aside from a jack and lug wrench, get one of these. You can get the same thing as 2 or 3 seperate tools but this is fine for casual use.
1000% easier than anything else you will find in your tool box.
Only take apart one side at a time and note which side the larger shoe is on; front or rear.
jbolty is offline
post #3 of 17 Old 02-17-2012, 11:45 AM
TheRobster
Also a large hammer, Small vise grips, and needle nose pliers.
Check out my cheep bastard Jeep mod blog.
TheRobster is offline
post #4 of 17 Old 02-17-2012, 11:56 AM
jbolty
jbolty's Avatar
Actually you need one of these too. I thought it was built into the other one, but after looking again it's not.
jbolty is offline
post #5 of 17 Old 02-17-2012, 12:22 PM
EABiker
I always like to take a picture of the innards before I tear it apart; sometimes it's not real obvious what goes where which way!
EABiker is offline
post #6 of 17 Old 02-17-2012, 12:39 PM
jmmorgan82
2009 JK Wrangler
The last time I worked on drum brakes was probably about 12 years ago in high school. I just pulled the outer drum off of each side, then pulled everything off of one side and used the other as a reference to reassemble. Rinse and repeat.
jmmorgan82 is offline
post #7 of 17 Old 02-17-2012, 12:40 PM
rocketboy
rocketboy's Avatar
Or you can just jack up both sides at once and look at the other side for reference.
rocketboy is offline
post #8 of 17 Old 02-17-2012, 12:59 PM
TheRobster
You know, I have done drum brakes more times than I care to remember, and I have never figured out just what the heck that tool is supposed to do.
post #9 of 17 Old 02-17-2012, 01:10 PM
86YJSEANVA
1986 YJ Wrangler
That tool is for the springs. It makes it so much easier to put the springs on and safer when taking them off.
rugginTJ01;9379588]yeah, driving a happy meal on wheels during crazy wind is so much fun :laugh
talentjeep;8785973] I'll go ahead and add cardboard to my regular maintenance regimen. Originally Posted by Diamond-x Didn't the 'check shock' light come on?
86YJSEANVA is offline
post #10 of 17 Old 02-17-2012, 01:22 PM
Day215
All of the above tools are indespesible, I hate doing drums but the tools make it much easier. I would pick up a brake spoon for adjusting the shoes and also a cylinder clip to keep the pistons from popping out on you. Take your time, you'll be a pro when your done.
Day215 is offline
post #11 of 17 Old 02-17-2012, 02:03 PM
TheRobster
Maybe I just need to see someone use one one day. I have just never been able to figure out exactly how you use it.
post #12 of 17 Old 02-17-2012, 03:18 PM
pasinbuy
Those tools do make the job a bunch easier. You can still do the job with a couple pairs of pliers and screw drivers.
Buy the tools.
pasinbuy is offline
post #13 of 17 Old 02-17-2012, 06:35 PM
brentd711
Good hand soap....GoJo with pumice works well Started replacing mine last night
brentd711 is offline
post #14 of 17 Old 02-17-2012, 07:55 PM
TheRobster
You know what works even better? Rubber gloves. I get them from the local drug store. Box of 100 for just a couple of bucks. Works great. Plus you can change them any time, like just before putting in the brake shoes to avoid contaminating the shoe surface.
post #15 of 17 Old 02-17-2012, 11:16 PM
MDCustom
The tool I picked up years ago has the handle in the middle with a kind of flattened round end on side and that weird round piece that you see in those other pictures on the other end. ( I guess I will have to take a picture of it)
I find that it is the only tool other than the adjuster for the star wheel.
The round end with the tooth (see post #2) goes over the spring post at the top of the shoes. Rotating in the proper direction will catch a tooth on the long spring and allow it to stretch and clear the post. The other end of my tool (or the other handle in post #2) is used to put the spring back on. With the spring over the narrow handle, you put the end of the tool on the post and lever the spring to slide down the handle and catch on the post. Easy-peasy.
I only figured out this year (after many brake jobs) that the round end with the tooth unscrews and is re-installed on the handle backwards giving a tool like in post #4. That side is used for the two shoe retaining springs. Those springs are the short ones with the recessed washer and those annoying weird clips. It helps with the job but those clips are the least fave part for me. I find it easiest to hold the clip from the rear of the backing plate while pushing the sping/washer combination with the other hand. One or both hands can rotate the pieces the required 90 degrees until the clip catches on the washer.
Sorry for the long response...
By the way, The first one usually takes about 30 minutes. The second one about 5!
MDCustom is offline
Rear Drum Brake Help - Tight Drum AFTER new shoes! rastadog TJ Wrangler Technical Forum 31 10-21-2011 05:19 PM
8.8 drum brake parking brake cable? planedog YJ Wrangler Technical Forum 14 09-22-2011 04:44 PM
Drum brake or disc brake? BeepTheJeep Wrangler General Discussion 3 06-11-2010 01:00 PM
2001 TJ Drum brake to Disk brake questions javelin390 TJ Wrangler Technical Forum 0 03-16-2010 05:42 PM
Dana 44?? Regarding Disc Brake To Drum Brake samsammy23 TJ Wrangler Technical Forum 6 03-28-2004 08:44 AM
