Quantcast What tires size tires are you running on a 3 inch lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > What tires size tires are you running on a 3 inch lift
Old 01-15-2002, 12:36 AM   #1
afaletto
I would like to put 31's on my 94, and i thought shackles would be ok, but i dont hear the best things about them. Would 31's look too dinky on a 3 inch rough country lift. thanks
afaletto is offline   Reply With Quote
Old 01-15-2002, 05:13 AM   #2
bonehead99
I have the RC 3" lift with 31x10.50's and 2" shackles. It doesn't look bad, lots of room for flex, but I do think 33's would look better.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline   Reply With Quote
Old 01-15-2002, 07:06 AM   #3
Atropine
Im running 33's with a 3 inch lift. Under normal wheeling it does good, but under heavy flex it rubs in the back. Im looking into a 2 inch body lift. Heres a pic:
http://www.angelfire.com/trek/atropine/docs/jeep.html
If you want to see the jeep after the lift when I was running 30's click on the pic of the BMW and the Jeep
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline   Reply With Quote
Old 01-15-2002, 03:19 PM   #4
AJ
31's look good and fit without a problem, but could go larger. I've got a set of 33's sitting in the garage waiting for a re-gear before I mount them. I've got the 3"rc lift and it works great.
AJ is offline   Reply With Quote
Old 01-20-2002, 07:39 PM   #5
PuebloIV
I run 35s on my '91 YJ. The Jeep has a 4" suspension lift and a 2" body lift. Still I had to trim the flares quite a bit.
[url="http://mikes.rockcrawler.com/index.html"]http://mikes.rockcrawler.com/index.html[/url]
PuebloIV is offline   Reply With Quote
Old 04-19-2009, 08:09 PM   #6
blackattak
I am running 33s (33X10.5 BFG ATs right now) & have just ordered the 33X12.5 M/T MTZs with Classic II wheels for my unlimited. Have a 3" BDS suspension lift. Will eventually be changing fender flares to Bushwacker Flat Flares so rubbing (if it occurs with current setup) should be taken care of.
2004 LJ- 33X12.5 Mickey MTZs, Mickey Classic II wheels, 4.88 Yukon Gears, 3" BDS SL, Rockhard Rear Bumper with Tire Carrier & Rockers. Oil Pan, Warn Gas Tank Skid. & Differentials armoured, Iggee Seat Covers, Warn M8000 winch.AEV TT & tranny skid, radiator & steering box skids
blackattak is offline   Reply With Quote
Old 04-19-2009, 09:16 PM   #7
91YJRockCrawler
31s will look fine...i run 33s with a 2.5" lift so you can run 33s fine with some trimmming
im also am planing on doing a 1" body lift and running 35s with a lot of trimming
so if you really wanted to you could run 35s
91YJRockCrawler is offline   Reply With Quote
Old 07-01-2009, 01:57 PM   #8
Chris47222
I have a 2 1/2 rough country suspension lift on my LJ and run 33x12.5's with no rub during daily driving. A little rubbing when flexing on the trail. I have a 1.25" body lift in the garage that i haven't installed because i like the way it looks/behaves just as it is!
Chris47222 is offline   Reply With Quote
Old 07-01-2009, 02:04 PM   #9
X-tacy
I have 33" Maxxis's on with a 3" Pro-Comp lift.
-Chris
X-tacy is offline   Reply With Quote
Glock Forum
