What are these holes for? - Page 2 - JeepForum.com
post #16 of 28 Old 11-02-2011, 06:55 PM
danlee
1987 YJ Wrangler
Door surrounds, my 87 had a factory soft top with 1/2 doors, when I went to a hard top I had to pull all the hardware off and that is what I was left with.
danlee is offline
post #17 of 28 Old 11-02-2011, 08:21 PM
plumber1
^^ They are part of the Rock Hard Sport Cage, that I added on
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #18 of 28 Old 11-02-2011, 08:27 PM
soonermatt
Originally Posted by barr5150
Well now I have another question...I plan on buying a complete after market top not a factory top. Will I still need the holes/brackets?
I have the SuperTop and I welded those holes in. I also fabbed my own cage tie ins like yours. I'm liking your build.
soonermatt is offline
post #19 of 28 Old 11-02-2011, 08:40 PM
Wingnutt87
1987 YJ Wrangler
If your going soft top that plastic piece that goes there has a stud on it the holds the upper frame for the top
Wingnutt87 is offline
post #20 of 28 Old 11-03-2011, 06:10 AM
clush
I think you hit the nail on the head 94 - I have half doors and the plastic piece is needed for two reasons - to give the soft "upper" door somethign to snug up against and keep rain/wind, etc out - plus the little "teets" at the top hold the rail that the factory soft top snaps on to. I guess if you have full steel doors they might not be needed.
clush is offline
post #21 of 28 Old 11-03-2011, 06:39 AM
bogleparsons
^x2
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #22 of 28 Old 11-03-2011, 07:19 AM
mntbkrguy
I have the bestop aftermarket soft top which has 2 barckets with the "little teets" you described that are attached to the windshield using the same bolts the roll cage uses. So it is not required if you have a soft top but I can see where it would create a better seal if I had them.
http://www.quadratec.com/products/11002_9001.htm
A little off topic but.... I have also found that with my soft top from them I should really be using the uppers from a TJ that have the rounded corners instead of the YJ.
Mntbkrguy
1994 YJ 4.0
8.8 rear, 35's
mntbkrguy is offline
post #23 of 28 Old 11-03-2011, 07:57 AM
Doch80
Those holes are there for the factory soft top for the part JBolty linked to. If you get an OEM type soft top then you'll need them.
If you get a supertop then you don't need them. A long time ago, with another Jeep, I replaced the OEM top with a supertop and I want to say the instructions said to remove that door seal piece. I didn't and it worked fine. I'm assuming it'll work without it as the instructions said to remove them.
I personally wouldn't weld them up. I'd just put shallow screws in them and call it good.
Doch80 is offline
post #24 of 28 Old 11-03-2011, 10:49 AM Thread Starter
barr5150
Looks like the holes stay. Thanks for the help guys!
barr5150 is offline
post #25 of 28 Old 11-03-2011, 11:30 AM
seraph_rapture
Originally Posted by 94chb View Post
how much were those grab bars and where did you get them?
I second the question.
seraph_rapture is offline
post #26 of 28 Old 11-03-2011, 02:02 PM Thread Starter
barr5150
I like them too but it's not my jeep, "plumber1" posted a pic of his jeep. Looks like he says they are part of a "Rock Hard Sport Cage", maybe you could google it?
barr5150 is offline
post #27 of 28 Old 11-04-2011, 05:01 PM
jscott321
"What are these holes for?"
Those wholes are definitely for a plastic bracket that screws into the spot. On top of the bracket is a small post that help to lock down your full soft top. That bracket also creates a tightness between the door and the weather.
When you go to put the full soft top on, you extend the interior rack system. On the part of the rack that goes along the top of the door should be some snap buttons and a small plastic part with a whole that slips over the smaller post at the top of the bracket.
I just repaired my interior rack to put my top on and found out that is why you keep the wholes and plastic posts as they are. Good luck!
jscott321 is offline
post #28 of 28 Old 11-04-2011, 07:40 PM
GilNewJeeper
2008 KK Liberty
Originally Posted by jbolty View Post
Yes. There is a plastic bracket that goes there.
http://www.quadratec.com/products/11033_07.htm
Will those brackets interfere with the full doors ?...
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
Holes.... robertcrav Wrangler General Discussion 3 09-16-2011 04:33 PM
What are these holes for? 06flex TJ Wrangler Technical Forum 4 06-02-2007 02:57 PM
Axle bracket holes worn - how to repair holes? NCST8TJ TJ Wrangler Technical Forum 6 08-04-2005 04:43 PM
holes chaleau TJ Wrangler Technical Forum 6 12-03-2004 07:53 PM
Holes in tub floor (not drain holes) soccergk2003 YJ Wrangler Technical Forum 1 03-25-2004 06:58 PM
