what temperture does your yj run? - JeepForum.com
post #1 of 4 Old 07-27-2013, 09:12 PM Thread Starter
rtaylor
I changed thermostat in my yj to 190deg. but it run 160deg. How can I
get it to run warmer?
rtaylor is offline
post #2 of 4 Old 07-27-2013, 09:49 PM
jokerchief462
Yeah a couple things temp sensor and gauge may be the issue. Depends on year and engine but see if you have an issue with either.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 4 Old 07-27-2013, 09:53 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Change the temperature gauge sender at the back, driver side of the head. Mine ran perfectly, but the gauge only read 1/4 of the sweep. I changed the sender and it runs right at 210* on the gauge.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 4 Old 07-28-2013, 07:05 AM
Louie4
I run between 195 and 210. I prefer closer to 210.
Do as UltimatE said and change the temp sensor on the head. Are you sure you didn't put a 160 thermostat in by accident (store gave you the wrong one)? The temp is stamped on the bottom of it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
