what temp is too low? - JeepForum.com
post #1 of 9 Old 10-24-2011, 02:52 AM Thread Starter
ptwhaler
Summers over here are brutally hot, 115 to 125 on average with some days hotter. Most of the time my jeep holds it's own at 210 but will creep up a little hotter if I sit at a light too long, usually not too much to worry about. Now that the outside temperature has gone down I have noticed that most of the time the jeep is running at about 185, somtimes 195. Will this cause any issues with it not running at the normal operating temp?
Also, is it normal for a jeep to lose a little water every few days? I don't see any leaks, there is no indication of a bad head gasket yet every couple of days I have to put a little water in it to top it back up. If it is not leaking then where the heck is it going?
"In wine there is truth
In beer there is strength
In water there is bacteria"
ptwhaler is offline
post #2 of 9 Old 10-24-2011, 03:40 AM
sprngrider
You put tap water in your rad? That is going to leave behind mineral deposits in your system. Get coolant in there, I bet you wont have to top it off ever. Unless it is leaking from somewhere...
1994 2.5L WRANGLER S.
sprngrider is offline
post #3 of 9 Old 10-24-2011, 08:20 AM Thread Starter
ptwhaler
I do put coolant in there, but I top it off with a little water if I don't have coolant laying around. If there is a leak, I just don't see it. Except for the small oil leak I have but that's apparently normal for Jeeps
ptwhaler is offline
post #4 of 9 Old 10-24-2011, 08:29 AM
cwsluggers1
Mine leaks coolant occasionally out the heater core (I think) onto the floor of the passenger side. Every once on a while, I put a glass of tap water in the overflow container if its empty. We have hot summers here too but even now, highway driving gets the temp a little above 210 and the transmission gets tough to shove it in gear. These could be related but I'm not sure.
cwsluggers1 is offline
post #5 of 9 Old 10-24-2011, 08:52 AM
adamandjessyj
could be leaking from the water pump. there's a drain hole on the underside of most pumps and if the internal seal is failing it will drip out while your driving and disappear when you try to find it. oh and as far as running temp i like to be above 180 and below 210 with a 195 thermostat.
where thers a will, theres a way!
its not a just a truck, its my hobby.
adamandjessyj is offline
post #6 of 9 Old 10-24-2011, 09:16 AM
Spuznick242
I wouldnt really worry about my temp being too low unless there's a sensor or something wrong. You could use the scanner to make sure your computer is getting the right tempeture reading and as long as thats right it doesnt matter. I know my guage is quite a bit off from what readings I'm getting from my computer's readings.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #7 of 9 Old 10-24-2011, 09:35 AM
cwsluggers1
thats exactly what happens!! I see it on the floor (only occasionally) after driving and I haven't been able to detect where it's coming from
post #8 of 9 Old 10-24-2011, 11:37 AM
Apollo12227
The 4.0 was designed to run between 195(ish) degrees and 210 or spot on 210 in warmer climates. If you are running any colder than 195 then you need to replace your thermostat as you either have a defective or too low temp t-stat.
The 4.0 is a relatively hot burning engine, it is at peak performance when brought to factory operating temp.
Apollo12227 is offline
post #9 of 9 Old 10-24-2011, 12:49 PM
Que89YJ
If you have coolant on the floor then you have either a hose leak to the heater core or the heater core itself. Easy to fix and well documented. Look in the FAQ under heating/AC
Que89YJ is offline
Surface temp vs. internal temp InEmberClad YJ Wrangler Technical Forum 2 01-07-2010 06:04 PM
What temp should the temp guage be at? 6290988 YJ Wrangler Technical Forum 17 12-13-2009 10:01 PM
AC blowing hot--temp dial in cold, but temp dial was previously in hot greendot200200 TJ Wrangler Technical Forum 6 11-14-2008 06:26 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
