What t-case shoud I use with the th400? - JeepForum.com
post #1 of 3 Old 08-26-2011, 04:11 PM Thread Starter
2SFL
I am swapping a 79 amc 360 with the th400. Im not sure what t-case I should use can anyone give me some ideas. The tcase needs to drop to the right because im running a chevy 10 in the front and a 14 in the rear.
2SFL is offline
post #2 of 3 Old 08-26-2011, 04:32 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I could be wrong but I believe you could run a NP205 which is a gear driven case that was used in gm products. or I am sure Advance Adapters makes an adapter for you to put any tcase to just about any tranny.
To view the NEW
click here!!!
tobias94yj is offline
post #3 of 3 Old 08-27-2011, 10:27 AM
Dlambright
np205 or cj 300 ive even seen some 20's used. 205's are getting hard to find but they are bomb proof, have huge upgrade support and twin stick! Make sure you get the th400 version or you gotta swap out all the guts to get it to hook up. get the adaptor with it too if you can, they arent cheap by themselves.
Dlambright is offline
Shoud caster be increased or decreased when you add larger tires? jarrod318 JK Wrangler Technical Forum 8 03-10-2011 04:02 PM
TAX REFUND! How shoud I spend it on the Jeep? srlbotanical TJ Wrangler Technical Forum 15 03-08-2011 09:40 AM
top of head full of carbon 1 inch deep what shoud i do 92yjpittman YJ Wrangler Technical Forum 6 04-11-2010 10:07 PM
What gear shoud I put in my speedo- wildbadbill YJ Wrangler Technical Forum 5 05-19-2009 12:56 PM
Shoud I get it biplanefan YJ Wrangler Technical Forum 9 09-15-2006 11:05 AM
