what is the stock ratio on my YJ 1993 - JeepForum.com
post #1 of 8 Old 06-22-2010, 07:10 AM Thread Starter
thierryben
Hi , I have an YJ 4L 1993 with manual transmission ,
I have 4 tyres in 35" and for the time I have the stock axles , , I want to change my ratio for a 4.55 or a 4.88 but I must find the original ratio ,
please someone can help me , what is the original stock ratio on my axles ?
thierryben is offline
post #2 of 8 Old 06-22-2010, 07:18 AM
sloan74
4.10
go to 4.88, same price and better.
sloan74 is offline
post #3 of 8 Old 06-22-2010, 08:35 AM
WRMJeep
My '93 4.0L with manual trans was a 3.07 ratio. Depends on the jeeps package and options what the gear ratio is. Jack up rear pumpkin and turn the driveshaft and count tire rotations, or try to read the label on the diff. There are previous threads that talk about the procedures for each.
WRMJeep is offline
post #4 of 8 Old 06-22-2010, 08:52 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
a 4.0L with manual transmission is 99% of the time 3.07's.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 8 Old 06-22-2010, 09:03 AM Thread Starter
thierryben
ok , many thanks for your answers , and if I choose a ratio of 4.88 , do you think that I can change only my ring and pinion or I must change my carrier and my posi too ?
post #6 of 8 Old 06-22-2010, 09:04 AM
sloan74
crap i misread and was thinking 2.5l
sorry!
yeah should tell you on the differential covers, one of the bolts will have a metal tag attached, if you can spot the tag, clean it so u can read it, and it should tell you the ratio.
sloan74 is offline
post #7 of 8 Old 06-22-2010, 09:08 AM
MJMPC
From the FAQ
Gearing
I4 Automatic - 3.73:1
I4 Standard - 4.10:1
I6 Automatic - 3.54:1 (normally)
I6 Standard - 3.07:1, 3.54:1 or 3.73:1 - must verify with the tag on the axle or by pulling the differential cover and reading the numbers stamped in the ring gear or by counting revolutions of wheel versus driveshaft.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 8 Old 06-22-2010, 09:10 AM
grnsanddemon
If you have 3.07's then you will have to change the carrier. I think the carrier break is 3.73's. If you have 4.10's then the carrier should work.
grnsanddemon is offline
Stock Ratio? 5artist5 YJ Wrangler Technical Forum 6 01-23-2009 03:22 PM
Stock Gear ratio ???? notrace34 YJ Wrangler Technical Forum 3 04-12-2008 03:09 PM
TJ 4 cyl stock gear ratio roadbosstx TJ Wrangler Technical Forum 2 03-03-2008 10:07 AM
Help! Whats The Tow Capacity Of A Stock 1993 Yj 4cyl, Thanx ROADDOG516 YJ Wrangler Technical Forum 14 12-18-2007 01:39 PM
3.07 a nml stock gear ratio?? McJeepin TJ Wrangler Technical Forum 2 03-28-2007 01:21 PM
