what speed is your yj? - JeepForum.com
post #1 of 7 Old 03-24-2002, 05:35 PM Thread Starter
off-road arkie
O.K. here is the deal! i lost fifth gear in my yj and have pulled the tranny out . im thinking about just going back with a 4 spd but i cant remember how fast mine would run in 4th gear. i also need to know what RPM my motor is turning at 55MPH. sure could use this imformation
1987 6 banger " if it's runnin be happy" & 03 and it is running fine
off-road arkie is offline
post #2 of 7 Old 03-24-2002, 08:38 PM
Mr. Mopar
dude if you took your tranny out you already did most of the work. pull the rear part of the case off 5th gear is seperate from the rest its like they just added it in the back of the 4 spd. once you get in there bolt your shifter on and put it in and out of fifth and you should be able to see what part is giving you the problem. then that part to the dealer and get a new one , then put it all back together put your 5 spd back where it belongs. next step, and this is the most important part GO JEEPEN
major work done on a 4.0
KEEP IT JEEP!!!!!!!!!!
Mr. Mopar is offline
post #3 of 7 Old 03-24-2002, 08:52 PM
Keymaster
Keymaster's Avatar
I have the same size tires but I have a 6 cyl. and we have different gears, so I don't know how similar our Jeeps go up the road. My jeep at 55 mph is turning almost exactly 2000 rpm's in 4th gear. I rarely use my 5th gear. If I'm going more than 65 on flat ground or going downhill I may use it, but if not I just stay in 4th. In 4th gear at 65 I'm only pushing about 2400 rpm. Hope this helps ya out.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #4 of 7 Old 03-24-2002, 09:08 PM
KYgreenYJ
isn't there a different transmission in a 2.5l jeep than a 4.0? if so that would make thos numnbers above pretty useless or am i just not thinking str8. and with the gear ratios and tire size you should be able to figure that out w/ a calculator just don;t ask e how i sleep everyday in math class.
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #5 of 7 Old 03-24-2002, 09:13 PM
KYgreenYJ
opps sorry i didn't read that whole reply i guess he mentioned the gear difference between the 2.5 and 4.0
Old Jeep, SOLD:
post #6 of 7 Old 03-24-2002, 09:24 PM Thread Starter
off-road arkie
the reason i want to know all of this is because the main shaft is shot (kapoot) the cluster gear is (kapoot) also . but you can put them back in and leave 5th gear out and drive it that way. I just afraid it will overwind my motor at 65MPH and wear it out THANKS for the replies---jeep-on
post #7 of 7 Old 03-24-2002, 09:37 PM
Mr. Mopar
not sure dude sorry, try asking a tranny shop
A/C blows defroster at high speed, regular at low speed tumminello123 TJ Wrangler Technical Forum 3 07-12-2009 12:15 AM
will a 95 cherokee np231 from a 4.0 5 speed fit on my 99 wrangler sport 5 speed? subzeroedj TJ Wrangler Technical Forum 2 08-15-2008 10:35 AM
HVAC Fan Speed Low speed doesn't work (links to photos) mushupork TJ Wrangler Technical Forum 6 08-02-2006 09:14 PM
2.5 liter speed ?. Cruise speed 33'12.5" ironwoodsmith TJ Wrangler Technical Forum 10 05-31-2006 02:28 PM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 09:33 AM
