What spark plug gap on the 4.0L? - JeepForum.com
post #1 of 7 Old 10-06-2011, 01:41 PM Thread Starter
AnonymousD
I can find my Chiltons OR my Haynes manual and I can seem to really find anything searching around. So what should I gap them to?
AnonymousD is offline
post #2 of 7 Old 10-06-2011, 02:03 PM
dillonjm
2013 WK
IIRC its .035
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 7 Old 10-06-2011, 05:41 PM
rkham11
.035 is correct
rkham11 is offline
post #4 of 7 Old 10-06-2011, 05:49 PM
kahjeep
^^^ what they said!
kahjeep is offline
post #5 of 7 Old 01-04-2013, 03:31 PM
maxthegi
I knew that if I searched this forum I would find the correct gap somewhere. Thanks for y'alls help.
maxthegi is offline
post #6 of 7 Old 01-06-2013, 12:51 AM
seattle_yj
Most of the higher end plugs are pre gapped. If you buy from napa they will tell you if it's pre gapped or not.
seattle_yj is offline
post #7 of 7 Old 01-09-2013, 08:20 AM
TA-YJ
Always double check the gap. Ive seen "pregapped" plugs that are like .015-.02 off.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
spark plug johnnyfitz14 YJ Wrangler Technical Forum 2 11-16-2008 03:03 PM
Best Spark Plug for 05 4L SCDolphin TJ Wrangler Technical Forum 12 11-01-2006 08:50 PM
4.2L spark plug gap? 98formulaLS1 YJ Wrangler Technical Forum 6 08-30-2006 07:20 AM
spark plug gap help bokey YJ Wrangler Technical Forum 14 05-30-2006 07:08 AM
