What size wrench will I need to remove Front and rear drive shaft? - JeepForum.com
post #1 of 4 Old 08-28-2009, 01:45 PM Thread Starter
Jeepsr4me19
1976 CJ5
Yeah i know go out there and look!, but My junk is all been changed out so I need to know what size wrenches to remove the STOCK front and rear drive shaft. For the Front All I need to know is the size wrench for the ujoint at the axle, not at the transfercase.
Jeepsr4me19 is offline
post #2 of 4 Old 08-28-2009, 01:53 PM
jbolty
jbolty's Avatar
For the ujoint straps 5/16 or 8mm, depending on year.
jbolty is offline
post #3 of 4 Old 08-28-2009, 02:02 PM Thread Starter
Jeepsr4me19
1976 CJ5
thanks. that front and rear? I cannt remember for some reason. And i not long ago pulled both of them.
post #4 of 4 Old 08-28-2009, 04:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually both, 8MM & 5/16" are interchangeable sizes with each other.
Yes, same front & rear.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
Bolt size for front drive shaft on transfer case side UrbanGator TJ Wrangler Technical Forum 7 05-13-2014 12:32 PM
OK to remove rear drive shaft??? coorsmgood TJ Wrangler Technical Forum 16 08-31-2011 07:53 PM
Front Drive Shaft Nut size Finsup TJ Wrangler Technical Forum 6 01-23-2010 03:07 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
