What Size tire can I run?? - JeepForum.com
post #1 of 10 Old 06-04-2002, 07:31 AM Thread Starter
FastX
I own a 95YJ that I have had for six years. My jeep is my everday driver but I dont put on alot of miles. I like the woods, as I am sure you all do but I need to keep it practical. My plan now is swaybar disconnects and a telescoping track bars. That should help me in the woods but not compermise my street ride.I recently put a 2.5" Skyjacker soft ride under it and 0" lift greasable shackles. Now my question is what tire and what size to get?? What do I need for back spacing on my rims? I think i can run 33" on the street but will the rub to much in the woods? Also I was thinking of running boggers with beed locks. Then I can run low air pressure in the woods to help so more. But the tire is a soft compound and will it wear out to earler even though I dont put alot of miles on? So hopefully knowing what I want to accomplish you guys can help me out. Thanxs fastx
FastX is offline
post #2 of 10 Old 06-04-2002, 07:42 AM
Bob K
Bob K's Avatar
Typically 30" is as big as you can go on a stock YJ without getting any rubbing. If you want to go bigger there are two tricks.
1. Bump stops. I have a brand new set of four to sell for $25 includes shipping cost.
2. Trim away the flat, vertical edges of the plastic flares. Also makes the Jeep look cool and lifted.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 10 Old 06-04-2002, 08:49 AM
RCHavok797
RCHavok797's Avatar
Bob he says he has a 2.5inch lift on his Jeep. I would think 33s would rub to much offroad, 32s would probably be better. I have a 2 inch lift with 31s.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 10 Old 06-04-2002, 08:56 AM
Bob J
Bob J's Avatar
1984
I would stay with 31"s for full articulation with the sway bar disconnects, you probably wont get much from the telescoping track bars, I never bothered with them on my YJ and I was running pretty much what you plan on doing.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #5 of 10 Old 06-04-2002, 08:58 AM
BzJeep
BzJeep's Avatar
Im leaning more on the 31x??x?? side for that lift. If you ever do anything really flexy where you are trying to get 32x??x?? might rub. Thats only if you don't do something to your flares. Also the bumpstop thing would help in turning, to make sure you don't rub when your trying to turn the whole way.
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #6 of 10 Old 06-04-2002, 09:04 AM
AllanAlxndr
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by SPEED:
<strong> Also the bumpstop thing would help in turning, to make sure you don't rub when your trying to turn the whole way.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">With the appropriate backspacing on the wheel, there shouldn't be any rubbing on full turn, if you are referring to the rubbing on the springs...
I think you best bet would be to go with the 31's. You didn't mention your engine size but 33's will kill your power and this is your daily driver. I run 33's with 6" of lift and have tons of room for a stuff.
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #7 of 10 Old 06-04-2002, 09:32 AM
damonejeep
I agree with some of the posts, 31"'s will be your best bet.
And unless you are planning to tackle rock crawling, beed locks will be over kill. I am not saying do not do it, but if all you are planning to tackle is wwods and lite off-roading, then save the money and buy a set of really nice mud-terrains.
Just my $.02.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #8 of 10 Old 06-05-2002, 05:50 AM Thread Starter
FastX
Hey guys thanks for the ideas. Yesterday I borrowed a set of BFG A/T 33" 12.50 on 15"10" rims. Then I took off my swaybars and tested it out. I did get some fender flare rub but it wasn't to bad. I plan on getting the wide flares so may-be that will help. They were fine on the road but I think they stick out to much. I had 30" BFG A/T on so I was hoping to be able to run alittle bigger than just 31" So now I am thinking 32" 11.50" on 15"*8" boggers with lockers but I dont think you can get the boggers in that size. Any other ideas will be helpful. Thanks again Brad
FastX is offline
post #9 of 10 Old 06-05-2002, 02:02 PM
Dan Morera
Dan Morera's Avatar
If you put 33"s you better think gears also. Don't know what you habe right now so I might be wrong.
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #10 of 10 Old 06-06-2002, 09:55 AM Thread Starter
FastX
Dan do your tires stick out the side running the 31" 10.50s"?
FastX is offline
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 12:22 PM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 09:20 AM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 07:17 PM
What is the biggest size tire the factory spare tire holder will hold? keys741 TJ Wrangler Technical Forum 13 08-03-2003 02:59 PM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 12:14 PM
