what size tire can i fit???? - JeepForum.com
post #1 of 4 Old 02-07-2002, 11:59 AM Thread Starter
tufmar
Hey everybody, i was wondering the largest size tires i could put on my stock yj?? i think 31's are no problem, but can 32's or 33's fit??? thanks
93 YJ - 4.0 2" BDS 1" BL 33's
98 ZJ - 5.2 Limited 2" BB 31's
02 WJ - 4.7 Laredo 242 TC 3" IRO 245/75's
tufmar is offline
post #2 of 4 Old 02-07-2002, 03:07 PM
SBall
On a stock YJ, most people would not run larger than a 30" tire, myself included. You will experience rubbing,and if you go off-road, you will most likely tear up your fender flares and possible even your fenders. And dont forget that your stock springs have probably sagged somewhat since your jeep was built. Your best bet would be to get full length add-a-leafs and run 31's. Any larger tire and you will want a larger suspension lift. Body lifts, while not one of my favorite types of lift, are cheap and easy to install and provide up to 3" of lift. The again, you could always trim your fenders.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
post #3 of 4 Old 02-07-2002, 08:23 PM
bob91yj
If you're on a budget, the Rancho FULL LENGTH, (not the short ones, they break), add-a-leaf would be a good choice. Put a Daystar 1" body lift on, and you should be able to run 31's without rubbing.
The Daystar body lift is about twice the price of the plastic spacer body lifts, but worth it. It uses poly body mounts that REPLACE your stock rubber mounts. The spacer kits are exactly that a plastic spacer on your old rubber mounts.
You'll have to measure for full compression and full droop to get the right shocks.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #4 of 4 Old 02-10-2002, 02:52 PM
NOVA Jeeper56
ok I was in your shoes. I went ahead and put 31's on a stock sus. and regreted it. Then i invested in a rancho full length 2.5 inch lift with shocks and steering stabilizer and am very happy and rub free. The kit you can pick up for about 300$$ and then you if you have it installed about the same price as the kit.
'94yj, rancho lift kit, 31x10.50 BFG mud's,intake,exhaust,wheels, warn 6000lb winch,lights,
bumpers/brush guard
(used to be known as BiggMike56)
NOVA Jeeper56 is offline
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 12:22 PM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 09:20 AM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 07:17 PM
What is the biggest size tire the factory spare tire holder will hold? keys741 TJ Wrangler Technical Forum 13 08-03-2003 02:59 PM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 12:14 PM
