what size is the Pitman arm Nut.. - JeepForum.com
post #1 of 11 Old 07-26-2010, 03:31 PM Thread Starter
giggityjeeper
I got a 1 1/4 and 1 3/8 one to samll barely and one to big lots, what is it metric...??
or inch 5/16, I gotta borrow one from work now, so I only want to take 1 home not 2 or 3...
I only got hte 2 and neither fit.... borrowing a pitman arm puller as well that will make thigns easier...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #2 of 11 Old 07-26-2010, 03:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I just replaced the power steering box on my '91 recently. I want to say that the pitman arm nut is 1-5/16" but I just can't say for sure.
According to this chart, it would have to be either 32MM or 1-5/16" for the nut.
English to Metric Conversion
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 11 Old 07-26-2010, 03:42 PM
Destr0
I don't remember when I did my XJ to ZJ pitman arm (funny, I too had to borrow the socket from work because I didn't have one the right size), but I believe it was 33mm...
I just brought home a whole set... :-)
*** Max beat me to it- looks like 1 5/16 = 33.3 mm, so my 33mm wasn't too far off- I know I used the metric set because it was there and had all the sockets ***
Destr0 is offline
post #4 of 11 Old 07-26-2010, 03:44 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I know for a fact that I don't own a 33MM socket (I've never seen one either, but I'm not saying they don't exist) but the socket I used did fit properly.
Max
Mean Max is offline
post #5 of 11 Old 07-26-2010, 03:49 PM
Destr0
Max
Hey, I am going on spongy grey cells from about a year ago. maybe it was a 32mm. I know I don't own anything near that big- I borrowed a set from the truck shop at work (we have a fleet of 16 big rigs). I know I used a metric set because they said I could borrow that one as long as I needed b/c they hardly ever used it! I know I got my arm off without too much trouble (I also used a pitman arm puller from Autozone tool rental).
~K
Destr0 is offline
post #6 of 11 Old 07-26-2010, 04:02 PM Thread Starter
giggityjeeper
thanks all, I grabed a 1 5/16... no metric that big here.....
trusting Max.... Im sure a 33mm would bfit to....
post #7 of 11 Old 07-26-2010, 04:02 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
~K
I think it's pretty "gray" for all of us that may have done it a while back.
I was hoping that maybe between your experience & mine we might be able to help him nail it down by way of the process of elimination.
Getting older (like me ) sure doesn't help........
Max
Mean Max is offline
post #8 of 11 Old 07-26-2010, 04:04 PM
cubewhiz
I also recall it being 1-5/16". Well, at least, I bought a 1-5/16" socket for something because it is in my tool box. I don't know of anything else I would use that size for.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #9 of 11 Old 07-26-2010, 04:29 PM
Nampa
1-5/16th or a 33MM is correct. I did my lift 2 days ago.
Remmember to PB blast the pitman arm if you want it to come off without cutting or breaking the puller.
Max is a trusted source, and usually has the answer or good idea for just about everything jeep related, his posts have saved me many times.
Thanks
Nampa is offline
post #10 of 11 Old 07-26-2010, 07:54 PM
RockWoRM
RockWoRM's Avatar
Yup, it is 33mm, but I also have a 1 5/16 to get the job done. It's a 'tad' bit sloppy, but it works.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #11 of 11 Old 07-26-2010, 07:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
WRM
That sounds good. According to the coversion chart I linked to earlier, 1-5/16" is 33.3MM, so what you're explaining sounds 100% accurate.
Max
Mean Max is offline
pitman arm nut size (thread size) 1CleanTJ TJ Wrangler Technical Forum 2 03-29-2010 06:30 PM
help please (what size nut on the pitman arm) guild66 TJ Wrangler Technical Forum 2 03-20-2010 08:40 PM
pitman arm to tie rod what size is the nut? GQ100 TJ Wrangler Technical Forum 8 09-13-2009 05:28 PM
Pitman Arm Nut Size? SillyPutty TJ Wrangler Technical Forum 2 05-11-2008 08:09 AM
size if pitman arm nut Fastbeeatch YJ Wrangler Technical Forum 4 07-13-2004 04:49 AM
