What Size Hole Saw to use on LED Tail lights - JeepForum.com
post #1 of 19 Old 04-01-2013, 06:30 PM Thread Starter
Robob69
What size hole Saw do I need for Rectangle LED taillights?
I am also installing 4" round LED Reverse lights...
I sure don't want to screw this up...
Thanks
Robert
Robob69 is offline
post #2 of 19 Old 04-01-2013, 06:51 PM
SeanB95YJ
Thanks
Robert
I'm not 100% sure I understand, because a hole saw makes a ROUND hole... can't put a square (or rectangular) peg (or light) in a round hole
now the 4" round reverse lights, those would probably take either 4 1/4" or 4 1/2... you'd have to look at the instructions (or template) that comes with the lights or the grommets
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 19 Old 04-01-2013, 07:00 PM Thread Starter
Robob69
The Rectangle holes are for the top and bottom of the light then I will cut the remaining with my cut off saw..
Robob69 is offline
post #4 of 19 Old 04-01-2013, 09:04 PM
SeanB95YJ
oh ok... in that case, you need to know the radius of the corners.
If the lights/grommets have 1" radius corners, then you'll need a 2" hole saw for each corner, then finish with the cutoff
swap/build thread:
post #5 of 19 Old 04-02-2013, 05:30 AM
lutzke21
The 4 inch rounds will take a 4 1/2 inch holesaw.
But verify with your grommet instructions.
The rectangle lights, there ought to be some instructions...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #6 of 19 Old 04-02-2013, 09:15 AM Thread Starter
Robob69
No instructions with these lights.... Bought them from Ebay and they are just the lights... Bright as hell but no information.
Robob69 is offline
post #7 of 19 Old 04-02-2013, 10:15 AM
roadyrob
1987 YJ Wrangler
you can use your grommet as a pattern and cut it with a jig saw. thats what I did with my 4" round cause I'm to cheap to buy a hole saw.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #8 of 19 Old 04-02-2013, 11:31 AM Thread Starter
Robob69
I am so excited to put these bad boys in the jeep.... I hate the dull looking dim stock lights...
Will I need to upgrade the flasher or put a resistor in line?
I am upgrading all the lights to LED not just the tail lights
Robob69 is offline
post #9 of 19 Old 04-02-2013, 11:37 AM
SeanB95YJ
most likely will need to change the flasher (unless someone else did before you got it)
try it without changing first.... if they flash funny (or don't flash at all) you'll need an electronic flasher... it doesn't rely on bulb resistance to trigger
swap/build thread:
post #10 of 19 Old 04-02-2013, 11:41 AM
flea1987
In order to use led's what kind of wiring changes need to be made?
flea1987 is offline
post #11 of 19 Old 04-02-2013, 11:44 AM
SeanB95YJ
no "changes" to the wiring at all... you'd just need to splice the LED connector pigtails in to your stock wiring at each light so you get the correct hi/lo of park/stop/turn
swap/build thread:
post #12 of 19 Old 04-02-2013, 11:49 AM
flea1987
Ok, just curious, had seen a guy talking about adding resistors and such on another post and made me wonder
flea1987 is offline
post #13 of 19 Old 04-02-2013, 12:03 PM
SeanB95YJ
most likely they did that because they didn't know about (or couldn't get) the electronic flasher
a standard flasher works off resistance in the circuit to make it open and close... in simplest terms it's an automatic momentary thermal switch... resistance causes heat and that makes it switch on and off.
an LED has hardly any resistance - especially compared to a standard filament type bulb, so you need an electronic flasher OR you can wire a resistor in the circuit to make the standard flasher "think" there's a regular bulb there
swap/build thread:
post #14 of 19 Old 04-02-2013, 12:10 PM
bgredjeep
1987 YJ Wrangler
I initially used a 4.5" hole saw. The lights didn't fit as tight as I would have preferred but I used some rtv and they stayed in fine.
bgredjeep is offline
post #15 of 19 Old 04-02-2013, 12:53 PM Thread Starter
Robob69
Thanks Y'all.... I am looking forward to this project!! Slowly getting her in some better shape then she was when I bought her!!!
Robob69 is offline
