what size belt for 4.2? - JeepForum.com
post #1 of 5 Old 08-08-2013, 10:49 AM Thread Starter
JMcDonaldKnives
1980 CJ7
Im removing my AC system on my 89 and cant find a number for a belt without AC. Anyone know the gates number for the serpentine belt for without AC but with power steering?
Director of Texas Jeeps Corpus Christi Chapter
My Build Threads
1980 CJ7 4.2L T177 D300 D30 AMC20 (under construction)
1989 YJ 4.2L T177 NP231 D30 D35 Pro Comp 3" lift 32/1150/15 BFG AT
JMcDonaldKnives is offline
post #2 of 5 Old 08-08-2013, 11:05 AM
jbolty
jbolty's Avatar
Best bet is to measure. Verify the correct routing ,run a string around and measure it. The belts part numbers pretty much universally contain the length in inches as part of the number. I difference of an inch is a pretty big amount so you might take more than one try to get it correct.
jbolty is offline
post #3 of 5 Old 08-08-2013, 12:33 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
This. It took me several tries to get a belt for mine. Still a little loose
Michaelgoesrawr is offline
post #4 of 5 Old 08-08-2013, 06:04 PM Thread Starter
JMcDonaldKnives
1980 CJ7
What size did you come up with? And what about a part number? I'm sure someone here has already done it and has the exact right size and the part number for it. After all this is a Jeep and is usually topless lol.
My Build Threads
post #5 of 5 Old 10-14-2013, 02:44 PM Thread Starter
JMcDonaldKnives
1980 CJ7
I finally got around to looking for a belt that will work. K060750 which is 75 5/8" gates belt but it is a little loose. A 75" wouldnt even go on but i think the magic number might be K060747 which is 75 3/8". Ill try it out later tho unless someone else wants to give it a shot and report back.
Sent from my Samsung Galaxy S4 using JeepForum
My Build Threads
