what should i upgrade first?? - JeepForum.com
post #1 of 16 Old 09-28-2010, 08:52 PM Thread Starter
360yj1989
I've got an 89 yj that the previous owner put a recently rebuilt amc 360 into. other than the motor it is pretty stock other than the 4 inch lift and 33" tires. the dana 30 up front also has a locker. I'm pretty sure it's got the ax 15 and your basic dana 30/35 set up. I want to do some mild offroading with the jeep and i'm afraid that this motor is going to make these stock components go off like a bomb. I forgot to mention that the motor has been bored out (not sure how much) and has an upgraded cam, roller rockers, 750 cfm carb, edelbrock performer intake and many other upgrades. I believe it is pushing 400 hp. my question is what should i upgrade first and to what? i'm on a very limited budget.
360yj1989 is offline
post #2 of 16 Old 09-28-2010, 08:56 PM
moonshinefuel
The rear axle probably, if its still the dana 35.
moonshinefuel is offline
post #3 of 16 Old 09-28-2010, 10:26 PM
MJMPC
Yep rear axle.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 16 Old 09-29-2010, 07:38 AM Thread Starter
360yj1989
Would a dana 44 be strong enough or would i need to save up for a 60?
post #5 of 16 Old 09-29-2010, 07:41 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
a complete set of 60's goes for 500-1000 around me. And if I were you would not waste my time with dana 44's.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #6 of 16 Old 09-29-2010, 08:22 AM
leadsled01
For comparison... I have a 1995 with 360cid,turbo 400 tranny, dana 44's from a scout2, OX lockers front and rear. I kept exploding front axle shafts and ujoints untill I upgraded to chromoly shafts and 300m ujoints ($750).. Everything is now holding up fine. If I was to build this rig from the ground up, I would just install stock dana 60's and be done with it.
leadsled01 is offline
post #7 of 16 Old 09-29-2010, 11:38 AM
BJsWrangler
this discussion has gotten me a little scared....I've got a 350/700-R4 turning my stock D30/35 setup. What causes the issue that requires upgraded axles? Is it just the more powerful engine? Or does it also have to do with the type of wheeling you do? Is this something that is just going to happen one day while I'm driving home from work?
Just for reference, my YJ is my DD, so I do highway driving with it all the time. When I wheel (I got it in Aug), its mainly going to be Jeep trails in CO.
"ROADS! Were we're going, we DON'T need roads!"
fuzz2010: "real jeeps don't have round lights, they have leaf springs"
tricked919: "Basic rule of thumb for me is if I see a front pumpkin, I give a wave. Otherwise they might as well be in a Corolla."
BJsWrangler is offline
post #8 of 16 Old 09-29-2010, 11:49 AM
Wrangler11
Wrangler11's Avatar
With the 360, there is no question the rear end needs to be swapped out first. I'd throw a 8.8 in and not a d44. Cheaper and stronger. They are also very easy to be found.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #9 of 16 Old 09-29-2010, 11:52 AM
jbolty
jbolty's Avatar
The D35 is a ticking time bomb. Someone will chime in here and say "it's the best axle ever and they wheel it hard and it never broke" Good for them. For every one of those stories there are 20 more where one broke pulling out of the driveway.
Long story short, if you go easy and especially if you have an auto trans, it might last forever. Or not.
Just make sure to carry spare shafts, tools and the knowledge how to swap them on the trail.
jbolty is offline
post #10 of 16 Old 09-29-2010, 11:56 AM
4.7stroker
8.8 all the way then an Atlas xfer case.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #11 of 16 Old 09-29-2010, 01:55 PM
Wrangler11
Wrangler11's Avatar
Dwayne
If he's got a np231 an atlas xfer case is a waste of money in my opinion.
post #12 of 16 Old 09-29-2010, 02:05 PM
4.7stroker
With an estimated 400hp ( I think that is high and I would stick it on a dyno to get facts) he stands a real risk of shattering the case if he gets a little froggy on the go pedal.
Dwayne
[url]
[url]
post #13 of 16 Old 09-29-2010, 03:45 PM
Wrangler11
Wrangler11's Avatar
Dwayne
I'm pretty sure its tq that effects the np231 and I am also pretty sure the np231 can with stand a decent about of tq.
post #14 of 16 Old 09-29-2010, 06:06 PM
Apollo12227
The 231 can be used safely in high HP aplications... Yes there is a higher probability of exposing any weaknesses in the casting, but overall the np231 is a cheap, reliable little toad.
Before I get hounded, let me put it this way... In a vehicle with a v8 conversion, would you put your money on the d35 or the np231 to give out first? My money is on the d35... My buddy's d35 went out 2 1/2 months after his small block was installed... the 231 is still alive, as well as the d30, with 37's.
Btw... dont lose the posibility of a ford 9" as the rear axle (and front axle if your feeling really ballsy)... D60-like strength, easy to re-gear, very light, legendary in name, and plenty of aftermarket support. Not saying it's better than any other axle in it's class, but still something to think about.
Apollo12227 is offline
post #15 of 16 Old 09-30-2010, 06:50 AM Thread Starter
360yj1989
as far as the hp estimate I am just guessing but the motor came from a 71 hornet with the stock horsepower being around 295 (according to the net) and with all the upgrades (cam, roller rockers, motor being bored out, compression being high enough you have to run 93 octane with a bottle of octane boost to keep it from diesling, 750 carb) i would say its gained 100 or more since birth. I've been dying to dyno it but i cannot find one close enough that it wouldn't cost me $100 in gas to get to. All i know is that it has way more power than required.
Which of these axles that you all have mentioned am i not going to have to do much custom fab work to get under the jeep?
axle , transmission , upgrade , wrangler , YJ
Best headlight upgrade for a TJ that does not require new wire upgrade? rescue6 TJ Wrangler Technical Forum 95 06-10-2015 07:46 PM
RE LA upgrade vs Clayton LA upgrade Dr_Jim TJ Wrangler Technical Forum 12 08-06-2010 03:20 PM
rubicon express LA upgrade or clayton LA upgrade jeepin01tj TJ Wrangler Technical Forum 11 01-30-2010 07:05 PM
first upgrade? bfolla06 TJ Wrangler Technical Forum 14 01-07-2009 09:21 AM
next upgrade? natrlbrnmudr TJ Wrangler Technical Forum 9 01-20-2004 12:44 PM
