what should fuel injection pressure be at? - JeepForum.com
post #1 of 2 Old 06-17-2013, 05:12 PM Thread Starter
JeepDude87YJ
I was wondering what a 91 yj 4.0 fuel pressure should be at? Mine is at 30-35 running and 40 off. Is this bad? Thx
-87YJ 5.5'' Lift 33x12.5 BFG Mudders
Injected 258, Pacesetter header and Borla
cat-back, F 8.8 rear with 4 disc brakes.
-91YJ 5'' Lift 33x12.5 BFG Mudders
4.0 5spd,
-99WJ 4.7L with hitch to tow them all...
Also assorted CJ-7's and YJ's...
JeepDude87YJ is offline
post #2 of 2 Old 06-17-2013, 06:53 PM
idaholtby
For a 1991...Your pressure should be 31psi and then 39psi with the vacuum line removed from the regulator. If you see a ~ 8 psi increase with the vac line removed from the regulator, and your initial is as you described, then your fuel delivery is good and not likely causing an issue.
idaholtby is offline
