What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift - JeepForum.com
post #1 of 4 Old 06-02-2008, 08:57 PM Thread Starter
Dwayne93YJ
Dwayne93YJ's Avatar
I am running brand new 4" Skyjacker Military Wrap Springs, 1" (lift) Skyjacker Boomerang Shackles, 1" Body Lift, 35" Tires, and Bushwacker Fender Flares w/ fenders trimmed. What are the best shocks to run considering that this is a daily driver first, off road vehicle second? I have a set of Skyjacker Nitro shocks on it now (about 6 months old), but not sure if I like them or not. Thanks again.
Dwayne
Dwayne93YJ is offline
post #2 of 4 Old 06-02-2008, 09:33 PM
veestan
http://www.quadratec.com/advisor/jeep_shocks/
If I'm not mistaken only the suspension lift matters for shocks, I am very happy and so is the wife with the superlift superide shocks.
[]lllllll[]
'89 YJ 4.2L 6cly
'06 H3, don't hate
'01 YZFR6
veestan is offline
post #3 of 4 Old 06-02-2008, 09:47 PM
TSEJEEPERS
I am running Bilsteins. Very happy with them. Have been running them around 5 years or so.
The only real way to tell which shock to run is to measure.
The best way is to take the shocks off. Find a buddy that has access to a forklift. Lift each tire up and measure both the articulated tire and the one that is compressed. Do this front and rear. Call shock people and give them the measurements. They should be able to give you a part number for front and rear.
Call vendor and give them the number.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 4 Old 06-03-2008, 12:15 AM
mdo817
Summit list the shock length's. I measured mine at full stuff and droop. Added a little to each and it's all good.
1992 YJ, Project In Work,Frame Off Done, Repainted, Herculined Interior, Back on the road.Self Fab'd front/rear bumpers & tire carrie,MM SE9500,lot's of Susp. 1" BDL,BrandonYJ Boomerangs, 33X10.5 BFG M/T, 4.0 AX-15,8.8 LSD,4.10 Gears, ARB Up Front,P/S Rocker Knockers with slider. 90 YJ now turned into a parts Jeep.
2006 WK 4X4, Wifes Ride (Grandkid hauler)
1995 YJ,4.0, AX-15, Bone Stock Wifes Toy
mdo817 is offline
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 02:44 AM
Good Shocks for a 3" Superlift and 1" body lift? Didley TJ Wrangler Technical Forum 8 04-24-2009 06:51 PM
4" lift + Boomerang shackles fit 35s??? Nate M YJ Wrangler Technical Forum 30 02-28-2009 05:31 PM
should i drop the transfer case with a 2.5" lift and 1" boomerang shackles?? eric0024 YJ Wrangler Technical Forum 5 09-28-2008 11:23 AM
4" RE/BDS vs. 2.5" OME Springs + 5/8" MORE Shackles + 1" Body and/or TJ Flares? KUJeeper82 YJ Wrangler Technical Forum 12 08-04-2007 09:45 PM
