What sealant is used on the floor pan plugs? - JeepForum.com
post #1 of 15 Old 06-01-2013, 08:14 AM Thread Starter
UZI4U
I cleaned up some rust the PO didn't get before bedlining the inside of the tub. I had to take out the 2 3/4" plug in the drivers side pan and it had some super sealant holding it in. Anyone know what the stuff is? I would rather use that than something like RTV or silicone because the bed liner won't adhere to those. JB weld would be a last resort.
MCLMM
UZI4U is offline
post #2 of 15 Old 06-01-2013, 09:35 AM
PA_YJ19
It's known as seam sealer, go down to ur local autobody or paint supply store and ask for it. Doubt ull find it at a parts store, other option is to order it online. 3m makes a good seam sealer...
PA_YJ19 is offline
post #3 of 15 Old 06-01-2013, 09:39 AM
schaef89
I got seam dealer at AdvanceAuto
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #4 of 15 Old 06-01-2013, 12:02 PM Thread Starter
UZI4U
I found some at Ace, of all places. Thanks!
MCLMM
UZI4U is offline
post #5 of 15 Old 06-01-2013, 10:09 PM
SuperMidget
i've pulled all the plugs out of the wife's jeep... makes it easier to clean up when i take the water hose to the inside
SuperMidget is offline
post #6 of 15 Old 06-02-2013, 08:34 AM
102joe
I leave mine out too , although it sucks when you forget they're out and and the river is a lot higher than you remember = wet feet
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #7 of 15 Old 06-02-2013, 10:23 AM Thread Starter
UZI4U
I
m considering that as well There's no increase in noise and I don't have any carpeting. I might fab some inserts for the winter to keep out the snow and slush.
MCLMM
UZI4U is offline
post #8 of 15 Old 06-02-2013, 02:58 PM
Cobra21
I got some plastic ones. I forget where I got them but they have teeth so when you tap them in they stay there. Really easy to put in.
Cobra21 is offline
post #9 of 15 Old 06-02-2013, 09:12 PM
gsnfl
Rubber expansion plugs from tractor supply. They have all the sizes in the floor and just need a wrench to tighten them up. About a buck a piece if I remember right
gsnfl is offline
post #10 of 15 Old 06-03-2013, 08:37 AM Thread Starter
UZI4U
If you can recall, let me know.
MCLMM
UZI4U is offline
post #11 of 15 Old 06-03-2013, 10:00 AM
boujo
Ebay, get some plastic ones. They are even black to match the bedliner
boujo is offline
post #12 of 15 Old 06-03-2013, 11:13 AM
superj
yup, thats what i have
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #13 of 15 Old 06-03-2013, 11:25 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I'm not 100% sure these little drain plugs are what you are after, but I used these from quadratec on our YJ.
http://www.quadratec.com/products/55005_51.htm
they stay in without sealer. I think you need 11 for the entire pan.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #14 of 15 Old 06-05-2013, 08:36 AM Thread Starter
UZI4U
Thanks, but those aren't what I'm after. The factory has 2 3/4" holes right in the center of the floor pans on each side. They have a metal plug and are glued in there with sealant. I'm getting some samples from a few manufacturers to see if they will work. Nobody seems to have 2 3/4" though.
MCLMM
UZI4U is offline
post #15 of 15 Old 06-05-2013, 08:58 AM
Firefyter-Emt
You do want a normal auto body seam sealer. Get a 1-quart can and an acid brush to brush it around the plug.
Firefyter-Emt is offline
